6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Manually Cleaning the DPF filter?
Old Oct 27, 2011 | 02:07 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
What the heck?
This is unrelated to the thread but did anyone else notice that they advertise chevy and dodge products on this ford forum?
Old Oct 27, 2011 | 02:10 PM
senix's Avatar
senix
Sound to me like one of the other codes that you didn't know has to do with the oil cooler then.
I think the updated EGR valve is slightly different design (don't quote me). Even with the old design there are not very many issues.
Old Nov 3, 2011 | 02:23 PM
fireman28's Avatar
fireman28
You can take your DPF off and take it and have it cleaned. Call some of your local diesel shops that deal with big trucks. They have to take theirs off about every 250k to have them cleaned. I was looking into it before I decided to do the delete.
Old Nov 18, 2011 | 10:04 AM
BigSilly86's Avatar
BigSilly86
Like A Boss!
UpDate
They are changing the EGR valve and the oil cooler, They are just getting to my truck today, Do you have to pull the cab to change an oil cooler?
Old Nov 18, 2011 | 10:15 AM
senix's Avatar
senix
nope. Both can be done cab on. Easily
Old Nov 18, 2011 | 02:36 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
Guess the dealership is making the mechanic take the cab off... Because the cab is on the lift at the moment. When I get the papers when its done I'll be able to tell exactly what they changed.
Old Nov 18, 2011 | 02:46 PM
senix's Avatar
senix
more than an egr and oil cooler then.
Old Nov 18, 2011 | 03:34 PM
Rudiak's Avatar
Rudiak
It seems it would be way easier to pull the cab since the oil cooler is inside the engine from what I have seen.
Old Dec 7, 2011 | 09:55 AM
BigSilly86's Avatar
BigSilly86
Like A Boss!
Just got my truck back this morning, they changed all the O-rings on the radiator, Changed the EGR valve, changed the oil cooler, changed the thermostats on the radiator, and performed a oil system flush and put new oil in the truck. I did not have to pay one red cent. They did pull the cab off the mech said he did this so everything would be easier to get to everything.
Old Dec 13, 2016 | 02:50 AM
Jas08F350's Avatar
Jas08F350
DPF Cleaning
So, I got the check engine light on my 2008 F350 with the 6.4L. The code reads Exhaust Temperature Sensor error side 1 bank 2. Every time I have the trouble codes cleared, I drive the truck somewhere and shut it off. When I start it back up, the same trouble code pops up. I have replaced 2 of the 3 Exhaust Temperature sensors, I took it to the dealer and had it "reprogrammed" and the same trouble code popped again. They cleared the code and said my DPF may be clogged and to take it on a long drive (basically what everyone else with this problem is saying) and the person said if they replace the system it's going to cost around $3000. So, I've got to ask, is there anyway to clean the damn filter or a way to get around the stupid "cleaning exhaust filter" crap? This is driving me crazy, I want to get the thing fixed but I don't have $3000. Any advice would be helpful. TIA
Old Dec 13, 2016 | 10:07 AM
brada's Avatar
brada
DPF cleaning
I see them all the time on Craigslist. Many take them off when tuning, just look for a low mileage one. I see them from $300-$700.
Old Dec 13, 2016 | 10:13 AM
senix's Avatar
senix
Would need a straight pipe and a tuner to get rid of the emissions. Look at DPF-R.
Old Dec 13, 2016 | 11:32 AM
  #28
speakerfritz's Avatar
speakerfritz
Originally Posted by Jas08F350
I've got to ask, is there anyway to clean the damn filter or a way to get around the stupid "cleaning exhaust filter" crap? TIA
soak it for an hour in 5 gallons of Berrys carb cleaner in a tall round kitchen trash can . then pour a gallon of fuel thru it. the berrys will look like tar but the DPF will be clean.
use gloves and do not get any of the dirty berrys on you skin......once contaminated with exhaust carbon....the solvent is very cancerous
Smokiesman
2004 - 2008 F150
Oct 21, 2016 12:01 PM
X-Phile336
1997 - 2003 F150
Dec 17, 2008 05:52 PM
bansheeduner
1997 - 2003 F150
Dec 14, 2008 04:38 PM
stormchaser1
1997 - 2003 F150
Jan 14, 2008 07:52 PM
Basshog98
Apr 3, 2006 01:58 PM
