starting trouble
Old Oct 23, 2011 | 03:14 PM
USMC5811mp's Avatar
USMC5811mp
starting trouble
so my 5.0 v8 started acting up a while ago it wouldn't start right after running for a while then it began running rough if i drove it to hard i replaced the distributor cap, spark plugs, spark plug wires, coolant temperature sensor, the thermostat, thermostat gasket, fuel filter, egr valve, air filter and some other stuff and still don't understand whats wrong sometimes if i get it started i can keep it running by fluttering the gas pedal or just flooring it but it lacks all power any idea's at this point would be great thanks a lot for reading.
Old Oct 23, 2011 | 03:34 PM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » TroubleShooting EFI Problems Click on this link, may help (assuming your truck is OBD1).
Old Oct 23, 2011 | 05:09 PM
Slip ford man's Avatar
Slip ford man
In addition to Lazy K advice, here is a good link on spark. You need to see if you have it, then it gives a direction for you/us to look Part 1 -Ford Ignition Module Test. Fender Mounted Module (ICM).
Old Oct 28, 2011 | 10:08 AM
USMC5811mp's Avatar
USMC5811mp
Spark
It has a spark at the distributor found that out the hard way
Old Oct 28, 2011 | 02:44 PM
Slip ford man
and....you need to be very descriptive since you have the truck... Did it start??? Very often with these trucks, after running awhile they stop running, and may start up again, when it cools off. A few ignition parts suffer this, the PIP circuit (inside the distributor) generally replaced with a new rebuilt distributor. The ignition control module ICM, generally replace with a new one, ignition coil, a relay, the computer, fuel pump, and a few others, you see the problem here. Checking for spark and finding it when the truck won't start, would maybe point to checking the fuel pressure. Checking for spark and not finding it on a warm motor, would point to the items listed above. Its an elimination game that you need to play, thoroughly read through those 2 links above. You need to have a full understanding of how things work, if you intend to fix her, and not have a shop do it.
Old Oct 28, 2011 | 03:07 PM
USMC5811mp's Avatar
USMC5811mp
The problem turned out to be I developed a fuel leak and have been out of gas for the past week
Old Oct 28, 2011 | 03:23 PM
Slip ford man
Very good!...you must feel a little fuelish
Old Oct 28, 2011 | 03:28 PM
USMC5811mp's Avatar
USMC5811mp
You have no idea I called off work because I had no way to get there and all it needed was some had lucky I have two tanks
spectra99
Jan 25, 2017 08:37 PM
John Faccinto Jr.
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 13, 2017 01:38 AM
Frmnsal
43
Jun 3, 2016 12:09 PM
88fordf150
Aug 31, 2005 12:20 PM
Jrock909
Nov 14, 2004 10:28 PM
