GETTING FED UP
Old Oct 20, 2011 | 10:46 PM
genemaas's Avatar
genemaas
I bought reman injectors. The thing is I had this problem before I bought the new injectors, wiring harness under both valve covers, and everything else. I even pulled the heads and found out I had one injector cup was cracked, so I had them all replaced.
Old Oct 20, 2011 | 10:50 PM
genemaas's Avatar
genemaas
It's funny how this thing reacts when cylinder clears up. I mean it's like grabbing another gear. It just ****s and gets.
Old Oct 20, 2011 | 10:51 PM
BigAlsPSD's Avatar
BigAlsPSD
Another possibility could be the EBPV sticking, but usually you can hear that...
Old Oct 20, 2011 | 11:09 PM
Shake-N-Bake's Avatar
Shake-N-Bake
That is what makes think about checking compression...
Old Oct 20, 2011 | 11:31 PM
hotroddsl's Avatar
hotroddsl
I would be going right to the main engine harness with a ohmmeter from the 42 pin connector to the injector connector pins on the vc plugs!
Jim & fat Monty
Old Oct 21, 2011 | 05:43 PM
genemaas's Avatar
genemaas
getting fed up
what is a EBPV
Old Oct 21, 2011 | 05:45 PM
genemaas's Avatar
genemaas
Today truck missed a little for a few miles them cleared up and ran great all day.
Old Oct 21, 2011 | 06:29 PM
hammer65's Avatar
hammer65
I am with Jim & Fat Monty. Check the connections where the harness plugs into the valve cover.
You did not mention replacing those harnesses.
Old Oct 21, 2011 | 06:31 PM
PaysonPSD's Avatar
PaysonPSD
I'm thinking like Greg. Possible low compression in one cylinder. As the engine warms that cylinder's compression will increase as the rings expand and compression ignition of the fuel becomes more efficient and the miss disappears. If it is worn rings you will begin to see more blow-by as the wear increases.
Why that cylinder seems to load up when at idle I can't really explain unless it does this at cold idle and not hot idle.
Hope it's not low compression and something others have suggested because those things would be much easier to deal with.
Edit: Forgot to mention the use of an IR temp gun to spot a cylinder that is misfiring. Aim it along the exhaust manifold. You may be able to find a cylinder with lower exhaust gas temps because of no fuel ignition, for whatever reason. This can certainly help you narrow down whch cylinder has the misfire. In your case do it right after a cold start.
Old Oct 21, 2011 | 07:53 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
how many miles on the truck? the fuel pressure seems a little high to me. 65psi should be the max but i dont think thats your problem. im leaning towards a worn out hole....
Old Nov 3, 2011 | 03:17 PM
genemaas's Avatar
genemaas
IF YOU DRIVE THE TRUCK ABOUT 10 TO 15 MILES, SHUT IT OFF FOR ABOUT 2 TO 3 MINUTES, START IT BACK UP IT WILL FINE. I BEGINNING TO THINK IT'S THE COMPUTER.
ANY OTHER IDEAS?
Old Nov 3, 2011 | 06:21 PM
BigAlsPSD's Avatar
BigAlsPSD
I really think a cold buzz test vs warm, or pulling the valve covers and watching oil discharge would help. If the injectors appeared to be in order I would move on to compression test.
BTW, you asked what an EBPV is, it is a butterfly valve in the exhaust stream that is engaged by an actuator at colder temperatures to aid with quicker warm up, some describe it as a jet engine sound, or hissing or leaf blower. Here is a thread with more information on the EBPV. https://www.ford-trucks.com/forums/1...h-exhaust.html
Old Nov 3, 2011 | 11:38 PM
  #28
hotroddsl's Avatar
hotroddsl
Alan & Greg you could be right! But it's a little too sporadic to be a cyl in my opinion, im still thinking electrical, but a comp. Test won't hurt!
Jim & fat Monty
Old Nov 3, 2011 | 11:40 PM
  #29
hotroddsl's Avatar
hotroddsl
ANY OTHER IDEAS?
WHY ARE YOU YELLING!!!!...lol
Jim & fat Monty
Old Nov 4, 2011 | 08:01 AM
  #30
genemaas's Avatar
genemaas
I'm not yelling. Sometimes i just type in capital letters. My wife tells me the same thing. Sometimes I don't feel like hitting the shift key. lol! Back to this truck. I'm going to replace the computer. A mechanic that works on diesels told me he had a truck that acted like that and he replaced the computer and truck runs great.
Everything you guys told me makes sense but the truck doesn't act like any one particular problem.
It doesn't matter if the truck is warm or cold. You start it up and it will run great or it will run like crap. IF it runs like crap, drive it for a while, turn it off, then restart in 2 to 3 minutes and two out three times it will run great.
I thought maybe the map sensor everybody says that's not it. So any way gonna spend a few more bucks and get a computer. Be nice if I could find someone that had a spare one laying around just to try it. So far no success there.
