headliner
Old Oct 20, 2011 | 08:31 PM
99hosss's Avatar
99hosss
headliner
Hello forum, will a 67 f-100 headliner fit my 66 f-250? thanks to all
Old Oct 20, 2011 | 10:20 PM
jhooch's Avatar
jhooch
No it will not.
Old Oct 21, 2011 | 07:51 AM
99hosss's Avatar
99hosss
thanks for the info
Old Oct 21, 2011 | 11:24 AM
Broomfieldbum's Avatar
Broomfieldbum
I have a digital pattern if you need one. Email me and I will send it to you.
I made mine out of Fiber Reinforced Panels, and it looks great.
Old Oct 21, 2011 | 08:02 PM
99hosss's Avatar
99hosss
That does look good, thanks Randy, I'll keep it on the back burner for now, saving up for paint.
Old Oct 21, 2011 | 08:14 PM
BigMikeUGA's Avatar
BigMikeUGA
What did you cut the FRP with?
Old Oct 21, 2011 | 08:28 PM
salf100's Avatar
salf100
What are FRP?
Old Oct 21, 2011 | 09:00 PM
Broomfieldbum
FRP is Fiber Reinforced Panel, available at any home store in the Bath section.
I cut it with a Dremel, but I will warn you blow the Dremel out often. I didn't and the Plastic built up and smoked my Dremel.
Old Oct 21, 2011 | 09:10 PM
BigMikeUGA's Avatar
BigMikeUGA
What kind of bit?
Old Oct 21, 2011 | 09:39 PM
Broomfieldbum
I started with a rotozip type bit, but found it hard to control, so I switched to a circular saw type bit.
Old Oct 21, 2011 | 11:29 PM
sapper4's Avatar
sapper4
Copy
Can I get a digital copy? Great idea by the way.
Old Oct 22, 2011 | 06:07 AM
jowilker's Avatar
jowilker
I have not cut curves in FRP but have cut it face down with a circle saw. Teeth will cut better, maybe a burr for final shaping. A saber saw with the material supported will work.
Plan ahead and go slow.
John
Old Oct 22, 2011 | 08:07 AM
BigMikeUGA's Avatar
BigMikeUGA
I didn't some Googling last night on cutting FRP. The general consensus (from plumbers) was that electric shears do the cleanest job. I might buy a set for the project because I've had many occasions where I needed them. $89 for a set from Northern Tool.
If you cut that stuff, you a respirator.
Old Oct 22, 2011 | 12:19 PM
jowilker's Avatar
jowilker
Mike you don't have to buy expensive electric, a set of hand operated aviators will work also.
John
C G B
17
Feb 20, 2025 01:36 PM
juang316
Sep 2, 2013 08:35 PM
pgr380
Jul 19, 2011 11:32 PM
xman7896
Oct 10, 2003 02:37 PM
