I'm working on putting in a play set in my backyard. The problem is that the terrain is uneven. We're talking ~1-6" from one spot to the next. How should I go about doing this? I'm only concerned with a 5' x 10' area. Any links or advice would be appreciated. Thanks.
I would just buy or aquire a 4x4 chunk of wood at least 5 foot long, grab yourself a level, then move dirt around till the board is level. The board will also serve to drag the area after.
For a 5x5 space you shouldnt need a laser level, but if you can borrow one, they work really well!
If the kids are gonna be jumping and climbing around on there, I'd put a bed of gravel. Bix in your play area with some treated 6x6's. Lay cloth membrane down inside to inhibit weed growth and fill it up with gravel. Don't use sand, unless you want a cat box.
If you want to leave it grass, but the ground is too uneven to support the posts of the play set, the easiest would be to pick up a few concrete slabs to prop up the posts on the low points.
If you want to grade the area, you need to have some soil delivered, level it out with a rake and shovel, and then compact it with a hand roller that you fill with water. You can rent the roller at the tool rental place. Rent a big aluminum grading rake too. YOu level it out with a small garden rake, pass teh roller to compact, then level again with the big rake, trying to get it really nice and even. Then roll over it again and smooth out the bumps with your big rake, until your satisfied.
Thanks for the advice guys. I got sidetracked. Not much time for the internets the past few days. I'm going to try and get to this this weekend. I have a level, shovel, and 4x4's....so I'll do that.
How about some rubber mulch instead of sand or gravel... I can only imgine the road rash I would have had as a kid if I was launching myself off swings, slides and monkey bars into gravel!!
I did a 10 x 10 pad ini my backyard a few years ago. After I got the sod out- really, a bunch of tiny clumps of grass- I pounded it out with one of these:
(I'll try the roller method next time- much less work)
I got it sort of flat and then added a bunch of sand- about 20 bags. Then I got a 10 foot long 2 x 4 and screed the sand to level it out. This looks much easier on television, btw. I laid the blocks down and several of them, no matter how hard I tried, still had a little wiggle in them. I simply added a little more sand here and there to make sure each block was steady. It came out pretty good.
Agreed!!!
Pulverized rubber, or shredded mulch. NOT rocks/pebbles!!!!!!!
I've been considering the pulverized rubber. The issue with doing mulch is that we get almost no direct light in the backyard (lots of tall hardwoods). Once it gets wet, that stuff would take forever to dry out. The soil takes long enough to dry out as it is.
This much I know - you'll never want to mow underneath it even with a weedeater.
Whatever you put down, underneath everything else NEWSPAPER (believe it or don't) permanently forms a barrier against weeds. There's something in the ink and binder of the paper that won't let weeds grow through a layer of it...
