Just noticed something strange. Tire question.
You should fill the tires to whatever is specified on the side of the tire, not the truck. Running a 65psi rated tire at 80psi is going to do nothing for your but cause premature wear. My current Michelin's have a max psi of 80 but I'm running them at like 62-63psi, close to the threshold before the TPMS light kicks on.
Your truck was shipped with tires that had a load capacity higher than the truck GVWR. Which is a good thing. This is why we have tire pressure load charts. The tire pressure that Ford printed on the label is correct when you have loaded the truck to its GVWR.
If you run the tires at 80PSI, you will enjoy a rougher ride and possibly wear out the center tread early. You might also enjoy a little better fuel mileage.
Sounds right to me. So, my plan stays the same. In the summer I will run them at 80 to deal with my trailer and quad combo that need all it can get. In the winter, it's down to 65. Thanks!
the manufacturer figures out the ideal characteristics that are affected by tire pressure, and tells you how to inflate your tires.
the sidewall is only the maximum allowed by THAT SPECIFIC TIRE
lets look at an extreme example
the corvair, when it first came out had a real problem with oversteer
chevy figured that if they decresased the front tire pressure, the increased slip angle of the front tires would equal out with the rear's tendancy to oversteer (due to the excess weight and poor suspension) and you would be left with a car with neutral handling.
IIRC, they decided to inflate the rear tires to the normal 35 psi and inflate the front tires to 17 psi or something like that
the problem happened when an owner decided to inflate the front to 35 as well and encountered massive oversteer as a result
the same is true with my truck.
my rears are set a 80 and the fronts are set at 50
this is the manufacturer's suggestion
the reason is that the lower pressure up front will give you a more wishy washy instantaneous turn in response... in other words, there is less of a tendancy to oversteer with a sudden steering input.
the higher rear pressure still allows you have maximum capacity from the tires
the second you install new tires that are a different tire than the one the truck was sold with, you have to figure this all out again on your own.
even a different tread pattern (or rubber batch) will change the ideal tire pressures.
in my case, i run 75 up front, and 60 in the back.
i find that the higher pressure up front allows me to get away with a poor alignment and still get even tire wear
the 60 out back gives me a softer ride, and since the rear tire wear is not much affected by tire pressure, then i go as low as possible without wearing the edges of the tires out prematurely.
its a balancing act.
Assuming SRW...
Simply put, the psi listed on your door jamb sticker is the psi needed for two tires to handle the axle weight rating as listed on the same door jamb sticker (either for the front or rear axle). Of course this only applies while using the OE size tire. Change the tire size and the sticker info will be worthless.
For example, for LT265/75R16 E rated tires: 50 psi is required for that tire to handle about 2335 lbs each. 55 psi = 2600 lbs, 70 psi = 3042 lbs, 80 psi = 3415 lbs (which is the max number listed on the sidewall of that tire size).
The axle weight rating listed on the sticker is computer chosen on the assembly line based on the option packages ordered on an individual truck by truck basis. The computer chooses the spring code, which comes with an associated axle weight rating and the tire psi is then chosen from the tire pressure load chart (which is an industry agreed upon load chart for a given size tire in a given load range). The psi listed on the sticker will never exceed the max pressure listed on the sidewall of the OE size tire.
If you are loading your truck near or over the axle weight rating then running max psi (as listed on the tire sidewall) is a reasonable practice. There is nothing wrong with exceeding the psi listed on the door sticker as long as you are not exceeding the psi listed on the sidewall. Like previously mentioned..the potential drawbacks would be ride quality and tire wear.
Assuming SRW...
Yes, I know and agree with all of what you said. Hence what I wrote above. When at or over my GVWR I'm now at 80. During the off season, I'm at 65.
I agree with what others have stated here.
