header gasket recommendations
Old Oct 19, 2011 | 12:07 PM
johnson2007's Avatar
johnson2007
I just bought a set of hooker headers that are used and don't come with gaskets. Are gaskets universal? What brand do you guys recommend! Anything else I need? Thanks!
Old Oct 19, 2011 | 01:18 PM
BIGT94z's Avatar
BIGT94z
i like perceys manifold gaskets bc they are multi layered soft aluminum and will not leak. any auto parts store should have them
Old Oct 19, 2011 | 01:46 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by BIGT94z
i like perceys
X2 on the Percy's, i've been using their "dead soft" aluminum header gaskets 8yrs plus (w/Stage 8 locking fasteners), i've had my headers off three times during that time period and reused the very same gaskets, and never had any leaks!
Ultra copper rtv works well too, but if you ever need to pull your headers you gotta scrape all that goop off and reapply, for that reason alone i prefer gaskets over rtv.
Old Oct 19, 2011 | 01:53 PM
HIO Silver's Avatar
HIO Silver
Just a couple of tips:
-Use anti-seize on the bolt threads. The PO of my truck used it and it looked from the outside that they'd snap off... lo and behold they came out like butter.
-Don't over-torque! Stock manifold bolts need, depending on the engine, only between 18-27 ft.lbs.
-After a few heat cycles re-tighten the bolts to "snug" or 2x with Montana_Highboy with Stage 8 hardware.
staysbroken
Dec 3, 2010 02:22 PM
OrangeJuice
Mar 25, 2008 09:03 PM
windevil pete
Dec 3, 2007 08:58 AM
inliner
Exhaust Systems
Aug 11, 2003 02:46 PM
Mil1ion
Jan 16, 2002 11:03 PM
