FUEL ADDITIVE/CLEANER
Old Oct 19, 2011 | 10:19 AM
knsahara's Avatar
knsahara
WHAT DO YOU GUYS RECOMMEND FOR FUEL ADDITIVE/CLEANER CETANE BOOSTER ?
Old Oct 19, 2011 | 10:44 AM
Rusty Axlerod's Avatar
Rusty Axlerod
All I use is DieselKleen. Available almost everywhere. Grey bottle in warm weather, white bottle when temps drop.
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid
DieselKleen can be found at autozone... smells like lipstick as my ol lady says
Stanadyne if you can find a retailer or buy online.
I fill up at this mom n pop place that only sells diesel they carry Stanadyne now. so Im waiting to switch to that soon as I finish off the Dieselkleen.
Old Oct 19, 2011 | 10:58 AM
tex25025's Avatar
tex25025
Don't use the stuff myself. Granted though, I don't deal with temps below single digits in both places that I call home, so that may have an affect on my decision there.
Old Oct 19, 2011 | 11:30 AM
zhilton's Avatar
zhilton
It's not just the low temperature protection. I run Diesel Kleen for the extra lubicity year round...gray when temperatures will stay above 40F; white all other times. The white has an anti-gel additive in it. In my opinion, ULSD is way too dry for the pumps & injectors on our trucks. If you can come up with either B5 (5% biodiesel/95% diesel), Stanadyne, Ford's Cetane booster or OptiLube (order online only) that's about as slick as your going to get your fuel. For the last six months I've been trying a blended DK-gray & OptiLube blend to see if that does anything for fuel mileage. I can't see where my MPG is any higher than straight OptiLube or DK-gray separately, so my theory is that there is only so far you can push the cetane (willingness to burn) of pump diesel.
Old Oct 19, 2011 | 11:36 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
WOW!!!! Sure glad I don't kiss YOUR ol lady!!!!!
I HATE the smell of that horrible stuff ..... but I use it at EVERY fill-up.
Old Oct 19, 2011 | 11:47 AM
zhilton's Avatar
zhilton
Wait until you get a whiff of OptiLubeBut it has helped my fuel mileage...so I put up with the smell. Just don't spill it on something your attached too.
Old Oct 19, 2011 | 01:13 PM
tex25025's Avatar
tex25025
Nary an issue with running straight pump diesel. I know beachbumcook is against running straight pump diesel, but I haven't had an issue with it. It's another one of those things with as particular as the injectors on a 6.0, I still haven't had any issues.
Which makes me wonder if it really is at that specific pump locations or does it have to do with ULSD in general.
Old Oct 19, 2011 | 01:36 PM
zhilton's Avatar
zhilton
Like I said, in my opinion, straight pumped ULSD is too dry for the pumps & injectors on our trucks. I have noticed a 1.5-2.25 mpg gain in fuel mileage over the last three years that I've been keeping track of my fuel (every gallon & mile has been accounted for). Is it the fuel, the additive or just straight driving style? I'd like to think is a combination of all three...but I still stand by my opinion.
Old Oct 19, 2011 | 01:55 PM
SixGunCaliforniaKid
LMAO I set myself up for that and didnt even know it, you got me... HA I say no more!!!
I get + 2MPG using the mom&pop diesel only station. I hate getting Fuel anywhere else and its hard cuz she closes at 5:30....
Old Oct 19, 2011 | 03:29 PM
Native Tex's Avatar
Native Tex
I have used DieselKleen and Lucas. My truck seems to run better on the Lucas.
Old Oct 19, 2011 | 04:06 PM
npccpartsman's Avatar
npccpartsman
I don't use it either.
Old Oct 20, 2011 | 12:19 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
FYI - I am not against straight diesel being used.... but I do believe that using a quality, name brand fuel additive (just for diesels) will only help one's motor in the long run.
I use Dieselkleen year round and actually double-dose most of the time. I use it more for the lubricity benefits than anything else... but clean fresh fuel, clean fuel filters and clean fresh oil is key!!!
No amount of additive will work if one doesn't spend the time and money to change their fuel and oil filters with OEM made filters and good clean oil changed every 5,000 miles (oil is used to operate the injectors).
Old Oct 20, 2011 | 06:26 AM
tex25025's Avatar
tex25025
Originally Posted by Beachbumcook
FYI - I am not against straight diesel beingused.... but I do believe that using a quality, name brand fuel additive (just for diesels) will only help one's motor in the long run.
That's being against straight pump diesel. If you thought straight pump diesel was sufficient for our motors you wouldn't use the additive period. Doesn't matter if you used it for cetane, lubricity, and/or anti-gel.
You certainly wouldn't double dose the additive if you thought straight diesel was sufficient.
I can't recall the exact post (you have many), but I could have sworn that you said that you wouldn't trust the fuel companies to quality control their additive and how much additive that they put back in the fuel to replace the "missing" sulphur and as such, you wouldn't trust straight pump diesel.
I'll try to find that specific post, but I could have sworn that you said something along those lines.
Old Oct 20, 2011 | 08:51 AM
Beachbumcook
Got Diesel?
Wow... I have no idea if I posted that or not... but it does sound like something I would say (and I do believe that for the most part)!!
I have learned that some here at FTE don't like it when people post absolute answers... so as far as fuel goes.... you rright, I use additives for what I believe are positive benefits and have always done so. By the same token, I know others here and on other forums that don't use them and have never had an issue.
These people are either lucky or live in an area where the fuel quality or cetane levels are higher or better controlled???
I probably did post what you think you remember... dam, that had to be a long time ago???
I now have 200,300 miles on my Excursion and replaced all 8 injectors last year at 180,000 or so. They became weak and sluggish with a huge loss in power.... but all is well now.
