How to remove silicone???
Old Apr 9, 2003 | 07:42 PM
Edidiesel's Avatar
Edidiesel
Unhappy How to remove silicone???
Big Mistake - when buying new F250 superduty bought the "package" which includes undercoating, treatment on interior and treatment on paint. I thought the interior treatment would only be like a scotchguard treatment on the carpet and seats well they put this "silicone" type stuff all over the dash, doors, steering wheel, etc., (anything plastic) wellllll it is terrible and I can't get it off. Took it back to dealer and they made it worse. Any suggestions on what to use to get it off. Sure would appreciate any advice. Thanks
Old Apr 11, 2003 | 06:22 PM
rvfiver's Avatar
rvfiver
Most solvents that are strong enough to remove silicone would most likely also do damage to what the silicone is on. You might try a product called "Goof Off" put out by Gardsman. It removes dried latex paint, oils, ink etc, and is safe for plastics, vinyl etc. Available at most hardware stores. Have no idea if it will work on silicone, but its worth a try. Use it in a small unseen area first just incase. Hope this helps. Happy trails
Old Apr 30, 2003 | 11:34 PM
GB's Avatar
GB
I don't think you are going to find any product that will get rid of that silicone. The stuff is highly inert and won't react to solvents, as far as I know. I've had detailers overdo silicone on my dash and plastic/vinyl... a little goes a long way. I've had the best results from using a clean dry cloth on the areas you're talking about. The cloth will pick up a good amount of the silicone, but not all of it. What's left will eventually disappear.
Old May 1, 2003 | 05:57 PM
2FordTrucks's Avatar
2FordTrucks
Try using dishwashing soap. Put some straight on a rag and rub it in real good. Then go back over it with a wet cloth to get up the rest. I always use armor all cleaner on my dash. Not the shiny stuff but the cleaner. It comes in a white and light blue bottle. Use that after you use the dish soap.
Old May 1, 2003 | 09:50 PM
steve83's Avatar
steve83
Lots of mild detergent (warm soapy water) is your best bet.
Old May 2, 2003 | 09:10 AM
AlM's Avatar
AlM
Yo,
Yes, take it off; imagine what it does to the lungs and other organs too.
DBGrif91
16
Oct 16, 2013 06:01 PM
Smokedagin
20
Jan 9, 2010 09:09 AM
F250SDPowerStroke
Sep 26, 2005 10:50 PM
gpeade
2004 - 2008 F150
Jul 28, 2005 08:32 AM
ocdmachine
Appearance & Dress-Up
Feb 24, 2004 07:49 PM
