update and need help
Old Oct 19, 2011 | 06:01 AM
srqdiesel chef's Avatar
srqdiesel chef
new GP relay and 1 bad GP replaced, new starter and starter relay, , new FSV, dropped front tank, cleaned and replaced pickup, new injectors and return lines, new fuel lines from front tank to new E-pump and new IP. Why does it still take so long to start? I have to run the e-pump for 3-4 minutes and crank 3-4 times 20 sec ea, 2 minute cool down between. When it does start, if I hit the throttle it doesn't react for 5-10 seconds and when it does it stumbles and acts like it is fuel starved. When I replaced lines I did not replace the sections of metal hard line, but I blew them out with compressed air to be sure they are not blocked. Could it be the filter? I don't think that it has been run long enough for the filter to block up.
Old Oct 19, 2011 | 07:45 AM
86f250XLT-4x4's Avatar
86f250XLT-4x4
If there was slot of buildup it could already be plugged
Old Oct 19, 2011 | 04:34 PM
hawgystyle's Avatar
hawgystyle
Filters dont run much. I'd replace it anyways. Have you checked your injection pump? You said you now have a electric fuel pump. How did you bypass your mechanical one?
vernon71
33
Apr 15, 2016 10:07 PM
irishgot8
Oct 22, 2013 08:55 AM
catbird7
20
Jan 3, 2012 07:10 AM
srqdiesel chef
25
Oct 23, 2011 12:00 PM
Nxsov180db
Sep 26, 2006 07:52 PM
