Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
drum removal help
Old Oct 18, 2011 | 07:05 PM
bullydogcj's Avatar
bullydogcj
drum removal help
I just bought a 71 f750 4x4. I need to remove the wheel seal,and inner bearing. How do i seperate the hub and drum? Or is the wheel seal removed out the back of the drum?
Old Oct 22, 2011 | 05:30 PM
bullydogcj's Avatar
bullydogcj
Where is the best place to get the seal and bearing?
Old Oct 22, 2011 | 08:02 PM
80broncoman's Avatar
80broncoman
Look close at your seals and bearings they usually have the name of the company that made them and thier part number.
Sometimes you can find these things online.
And get to know shops in your area that work on big truck and ask them where they buy thier truck parts. These people sometimes can REALLY help you out of a tight spot with actual help or just info that helps. So treat them right.
Old Oct 23, 2011 | 10:33 AM
bullydogcj's Avatar
bullydogcj
Pulled the seal out its marked DT3A-1175-FA, I cant seem to find it anywhere.
Old Oct 30, 2011 | 10:02 PM
popops75&79's Avatar
popops75&79
Ditto on what 80 broncoman said and napa is always a good back up. Did you try to crossreference on line? Cr seals, national seals etc..
Old Oct 31, 2011 | 01:15 AM
rummur s.c.'s Avatar
rummur s.c.
where are you located?
Should be able to pretty easily do a dimensional look up.
Try Fleet pride, grainger, MSC, NAPA (with the right parts guy) etc etc.
Old Oct 31, 2011 | 11:51 AM
cj06's Avatar
cj06
would that be a ford # ?
Old Oct 31, 2011 | 04:34 PM
bullydogcj's Avatar
bullydogcj
I live in south west Virginia, I looked it up on MSC's website by size, got a good part number I could find on RockAuto. Installed it the other day. It worked great.
quakerj
Mar 2, 2015 07:03 PM
carchub
Jul 25, 2014 03:20 PM
ericconn
Oct 20, 2013 10:56 AM
CBFryman
1983 - 2012 Ranger & B-Series
Aug 16, 2006 04:32 PM
