Bad Run
Old Oct 17, 2011 | 10:28 PM
igirocks's Avatar
igirocks
Bad Run
All,
I have an 1986 Ford F250 4x4 with a 7" Lift with a complete new Jasper Engine and Transmission with 1000 miles on the engine. My brother completely rebuilt the the truck to include powertrain suspension etc. It has 2 - 20 gal tanks. The engine is a 351 Windsor w/ an Edelbrock manifold and carb. This truck also has a non eletrical starting system, so in case EMP I get to get home WOOT!
For the past several weeks I have had nothing but running issues. After thr ruck warms up I take it for about a 10 mile raduis from the home. However, everytime the truck acts like it wants to die when I when I step on the gas. So I have to pull over turn the truck off and let it sit for 5 mins. But, that is a temporary solution as I have to pull it off the road the next 2 miles and rinse and repeat until i get it home. I thought maybe it could be the pressure build up in the tanks NOPE. I also thought it could be 1 problem with 1 tank so I switched to the other tank NOPE. Lastly, I thought is could be crap in the tanks so I installed 2 clear inline filters 1 going to the carb from the eletric pump and 1 from the supply hose going into the pump, and still I have problems.
I want to check with you guys first and see if I could get a rational opinion.
Many thanks guys....
Old Oct 17, 2011 | 10:51 PM
ctubutis's Avatar
ctubutis
Welcome to FTE.
What kind of ignition system is on this engine?
Old Oct 17, 2011 | 10:53 PM
igirocks's Avatar
igirocks
MSE off road? dark out now
Old Oct 17, 2011 | 10:57 PM
4x484150's Avatar
4x484150
Welcome to FTE!
Is the carb set right? Also, check for spark if its getting gas, like the firing order. Ya know, the simple stuff. (it's overlooked sometimes)
Old Oct 18, 2011 | 04:37 AM
cj06's Avatar
cj06
check the timing , also check to see if the ignition is wired up rite !
Old Oct 18, 2011 | 07:47 AM
Herb Brooks's Avatar
Herb Brooks
Advance and accelerator pump come to mind first. Check for vacuume leaks and float levels.
Old Oct 18, 2011 | 12:55 PM
igirocks's Avatar
igirocks
Found it I believe
All,
Thanks for participation in this discussion.
I believe I found the problem.....
I checked the vacuum and discovered a potential problem.
The pump has 2 outlets (obviously) 1 hose was connected to a line under the front of the engine. The other was not connected to anything so I saw another tube (like) line and I put 2 + 2 together and figured it became disconnected. So I am to assume that both lines must be connected....
If 1 hose is to act as a breather then I incorrectly connected it but, I do not believe I am wrong. JIC if i am wrong please inform "the once shade tree mechanic 20 years ago...." LOL
tom solder
Nov 10, 2018 05:42 PM
JEFFFAFA
25
Jan 12, 2017 03:58 PM
Crazymug13
Sep 17, 2012 07:49 PM
cr506
Feb 23, 2008 09:56 AM
74hiboy
Jan 23, 2005 09:55 AM
