T5 5spd swap
Old Apr 9, 2003 | 03:00 PM
rogerf100's Avatar
rogerf100
Question T5 5spd swap
Has anyone tried to install a T5 trans to a 292 Y block in a 53-56 F100 using the modified bell housing sold on John Mummerts site www.ford-y-block.com ? Sounds like this would be a good swap for the 3 speed. Which T5 trans would work? I have heard that the one from the 5.0 small block has a larger diameter input shaft than the one from the 2.3 L. I did find out that a special pressure plate is needed from John Mummert to make the swap work and a spacer for the clutch fork.
