Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
measuring tools
Old Oct 17, 2011 | 08:31 PM
Pili's Avatar
Pili
measuring tools
I need a dial caliper 0-6, dial indicator, snap gauges, bore gauges and set of mics 0-1 - 3-4. I wanted to get Starrett but I've heard that quality is not as good as it used to be. Any suggestions? They are for work and need to last.
Old Oct 25, 2011 | 09:51 PM
Pili's Avatar
Pili
bump.. its been over a week. No one has any opinions?
Old Oct 25, 2011 | 11:41 PM
fixnair's Avatar
fixnair
I don't care what they say Starrett is the best
Old Oct 26, 2011 | 12:39 AM
Ford_Six's Avatar
Ford_Six
Mitutoyo for analog measuring devices, and Harbor Freight snap gauges work well for me. I had a small set of Starrett micrometers, but I just didn't use them often enough to justify what I spent on them. The best micrometer I had was a Mac or a Snap-On branded one that went from .3 to 1.3" for brake rotors. It had an extended anvil to clear obstructions, and was quite accurate. I still have that somewhere I think-
Old Oct 31, 2011 | 02:38 AM
wdfp's Avatar
wdfp
By some older starrett's as long as the standard is with them to check and set them they will be as good as any newer ones.. if they haven't been misused like for a c clamp or something.. which I have seen done..
Old Oct 31, 2011 | 07:21 AM
cracked block's Avatar
cracked block
Hey Pili: check out the brown and sharp mic set on craigs list in Ocala, Fl. Maby it's something you can use. Tim
mstryker
Dec 16, 2009 10:57 PM
superfuzz87
Dec 30, 2008 02:21 PM
Ronin007
Modular V10 (6.8l)
Jan 2, 2007 12:01 PM
jvalich
Jan 19, 2004 04:15 PM
