flushing it out ...............
Old Oct 17, 2011 | 03:07 PM
55 f350's Avatar
55 f350
just like the title says guy's , you got any secret concoctions that'll clean out all the dain old casting sand in a flatty ??? the one in question is once again the 52's . been tinkering with it trying to get her right . sometimes she's fine then ........... this time i let her sit at a fast idle watching the temp gauge and a kitchen thermometer stuck in the radiator neck and all of a sudden comes a mud pie from hades outta the neck . it's plugged up internally with this crap and i'm letting it cool then gonna open up the drain , pull the top hoses off and fill the engine from there on both sides , stick the hose in it and let it flow ... or am i looking at trouble or do you have another way ???????
Old Oct 17, 2011 | 03:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The engine is tilted to the rear, so park on a steep downhill section. If you want to pull a water pump, that is the best way to get the junk out (one side at a time). You can also stick a 1/4" copper pipe connected to a hose back in thru there to stir things up. It sounds like you've got a lot of the mud loose, you just need to get it out. Some folks have drilled and tapped a drain at the rear of the block, but I'd be REAL cautious about doing that, the water jacket is up higher than you'd guess.
PS -- you need to pull the thermostats to pour water in the top
Old Oct 17, 2011 | 04:33 PM
4tl8ford's Avatar
4tl8ford
Remember that the two sides of the V8 are NOT connected except in the radiator - Also the passenger side temp sender measures the temp in that side while the drivers side sender is a on/off unit (Hot or Not)
Old Oct 17, 2011 | 04:41 PM
55 f350's Avatar
55 f350
tstats are out ross. just a washer in 'em . took one hose off at a time after darn near filling it , added some generic radiator flush , fired it up put the hose in the hose with water going full tilt and went back and forth like that { p.s. ran the car as suggested for a bit with the flush in it } till we got clear water then opened up the bottom drain on the radiator { and yep parked downhill / nose first in the drive , i can be smarter than i appear sometimes LOL !!!!!!!! }and kept doin it till i had clear water period . pulled the bottom hoses and refired it to get it all outta the motor then . and the top hoses off also . put it back together with fresh water and a lil' anitfreeze in case we had to pull it down again , fired it up and she was sitting at idle and me modulating the accelerator upon occasion and while the temp gauge went to the top she wasn't hot , just barely to the touch and you could pull the cap off without anything coming out from under it at all under pressure . so we wait a couple of days , recheck the timing , change the carb { got a blown power valve and such } and fire it up and go for a drive then if it passes refill her with a 50 /50 mix . got impatient waiting for the miracle cure ya know ....... LOL !!!!!!!!!!!!!!!!!
Old Oct 17, 2011 | 07:42 PM
38 coupe's Avatar
38 coupe
I like to put the engine at a fast idle, open all drain pet***** (some flathead have them in the block too), put a garden hose in the radiator so it fills at the same rate the pet***** are draining, let everything go until the water runs clear. Then take compressed air and blow back into the pet*****. Makes a heck of a mess, but knocks crud loose.
EXv10
Sep 14, 2012 08:48 PM
EXv10
Sep 7, 2012 04:46 PM
bsa_bob
Sep 29, 2011 09:10 AM
JMACC
Dec 31, 2005 10:03 AM
900rider
15
Jul 21, 2005 09:58 PM
