Buying advice
Old Oct 16, 2011 | 01:55 PM
The_SnowMan710's Avatar
The_SnowMan710
Buying advice
Hey guys.
Let me start by saying despite the fact that I'm a trained diesel tech, I've only owned gas burning vehicles my whole life. I've never really had much of a reason to own a diesel aside from the fact that they're totally b'dass and the occasional trailer I may pull once in a great while.
But, I happened across this ad on craigslist and I'm not gonna lie, it's got my temperature rising! I love the black and I'm sure she would shine up pretty nice. Every long box extended cab I've ever driven rode like a dream and I love 5 speeds because I think they're fun to drive. I know the mileage for this truck isn't that high at all and I figure if a guy could get the seller to come down from the asking price a little bit, it seems like a pretty legit deal.
Or am I wrong? I know a few things about the 7.3's but I'm certainly no expert. What are some common things I should keep an eye out for? Are there any things that would be a deal-breaker for someone who would want to buy it?
I was also poking around the sticky thread about the tuners and chips...has anyone had any really common problems with these motors tuning them back and forth for performance and economy?
here is the link to the ad, any and all thoughts and opinions are much appreciated in advance. Thanks guys!
-Kenny
'95 F-250 powerstroke
Old Oct 16, 2011 | 04:42 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Buying Used Power Stroke Diesels
Things To Look For When Buying A Used Power Stroke Diesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot. If it is the old style, you spend around $80 to update it.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg’s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed (http://forums.ford-diesel.com/cgi-bi...&f=21&t=005210), and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar – it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
Wish i could say these were all my ideas, but theyre not haha. oughta get ya started!
<!-- / message --><!-- sig -->
Old Oct 16, 2011 | 06:30 PM
The_SnowMan710
Thanks for that! some of those things I would not have thought of, even though I oughta know better...
jagarcia89
43
Jun 27, 2016 11:55 AM
BajaF250
Oct 29, 2011 03:40 PM
glovemeister
19
Sep 11, 2011 02:28 AM
390unibody
Jun 21, 2011 08:46 PM
79bluebronco
Apr 19, 2010 10:12 PM
