E4OD Shift Point Adjustment
Old Oct 16, 2011 | 08:50 AM
Chaos 95's Avatar
Chaos 95
Is it possible to adjust the shift points on a E4OD? Mine feels like it is up shifting to quickly from a stop and bogging down. If I shift manually, or start with the shifter in 2nd it is ok. I have a 95 F250, 351, 6" lift, 37" tires, 4.10's in the rear.
Old Oct 16, 2011 | 09:22 AM
Blurry94's Avatar
Blurry94
The only way the shift points can be changed on an E4OD, and other transmission functions, is with aftermarket tuning.
Old Oct 16, 2011 | 01:47 PM
Lazy K's Avatar
Lazy K
Did you recalibrate the speedo for the tires? If not the shift points will be off.
Old Oct 16, 2011 | 05:15 PM
rla2005's Avatar
rla2005
X2 Your truck uses a PSOM to divide down the signal from the rear VSS sensor. This PSOM supplies the drive signal to the speedometer/odometer as well as the Powertrain Control Module (PCM). Those tires you put on are throwing off the shift point calculations.
Old Oct 17, 2011 | 05:48 AM
lew52's Avatar
lew52
^^^^X 3...
Old Oct 17, 2011 | 08:07 AM
Chaos 95's Avatar
Chaos 95
Thanks for pointing me in the right direction. I'll post results after i'm done.
Old Oct 17, 2011 | 09:11 AM
Lazy K's Avatar
Lazy K
HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles Here is a link to a "how to" article, may help.
fhafer
Dec 14, 2015 04:03 PM
Cdy1
Jan 11, 2009 02:33 PM
mbertness
Dec 5, 2006 06:20 PM
maggie11
Mar 23, 2002 10:01 AM
