Traffic Accident in my 2010 F250 with 19K miles
#32
Here is the damage:
They have straightened the fender, replaced the bumper and bumper runner with an aftermarket item, "replaced" the tailgate and hitch.
I suspect they may have replaced the tailgate skin only - is that done or is it normal to put on a new tailgate?
The bumper was shifted to the left, so I guess the procedure is to straighten the bumper brackets.
Besides measuring the aftermarket bumper thickness, what else should I check for on final inspection?
#34
Anyway, what else should I be checking for when the repair shop says they are done and want me to sign off on it?
#35
I got to ask CornFlakes do you have a gasser or a diesel? I haven't seen an answer to that in any of the replies.
As for checking repairs what I did when I rear ended a Ranger and they replaced the front bumper I grabbed the front bumper shook it hard and looked to see if it was level in all respects.
Sorry I can't offer more/better advice than that.
#37
Stick to your guns man! Don't let 'em take advantage of you if you're actually using that hitch. Just like a carseat, a hitch is something that really should NOT be looked at and if they deem it to be replaced, make sure it's replaced of like or greater value. Don't settle for something else that YOU wouldn't put on your truck voluntarily!
I got t-boned (ish) by a drunk driver, who switched drivers, ran from the scene, had friends come up and harass me at the scene of hte accident and they both ended up arrested.
With that said, I dealt iwth my insurance because THEIR insurance wanted to replace my front door SKIN, BONDO my rear door, and pull the back of the cab out. The CRUMPLE zones on both doors were crumpled up and it would have been a mess to have them come out a thousand times to authorize what should have been authorized in the first place.
Came out nicely after all said and done with only a few tape lines..
-rockstate
-rockstate
#38
#39
Thanks, yes I use the hitch, I'm trying to clean out the barn and sell some old cars on eBay and need the pickup to move them around - but will regret getting it back if it's not like it was. What should I be checking for when the repair shop wants me to sign off on it?
I'm **** retentive, but remember that repairs won't always be 100% of factory, which it sounds like you've come to terms with.
I think my truck is about 90% to what it was on a full **** retentive scale.
#41
#42
That would be a great plan if I didn't have collision insurance and an uninsured motorists deductible of $250.00.
#43
#44
I will have to make sure the metal thickness as measured with a micrometer or spherical anvil micrometer is no less than the original, the chrome plate is smooth, not defective, no flaking or haze and the nickel is not exposed, especially around the bumper edges, the top runner is black, as thick as the original and fits onto the bumper correctly, I can use it as a step, the bumper blends into the body panels, that it is straight, the license plate lights are there and serviceable, I can remove the spare through the crank hole and the license plate is or can be properly affixed. Am I missing anything here?
#45
