EGR Code
Old Apr 9, 2003 | 02:22 AM
natencela's Avatar
natencela
Angry EGR Code
My '97 Expedition has a PO401 code. I have replaced the EGR Valve and the EGR Solenoid. Still getting the same error code. Any thoughts???
Old Apr 9, 2003 | 11:02 AM
1999XLT's Avatar
1999XLT
EGR Code
Did you clear the code? You can do it with your scantool or just disconect the negative battery terminal for a few minutes and that shouold clear the codes.
Old Apr 9, 2003 | 11:03 AM
Racerguy's Avatar
Racerguy
EGR Code
Hi natencela and welcome to FTE
The most common cause of a P0401 is the DPFE sensor. It tells the truck's PCM how much EGR flow there is. The die regularly enough that Ford has updated them and tells us that if we see a P0401 to just replace the sensor and dont even check anything else. Any dealer should have lots of them in stock.
Less likely is the EGR ports in the intake manifold are plugged but 99% of the time a new DPFE fixes it.
Old Apr 18, 2003 | 09:37 AM
itspete4's Avatar
itspete4
EGR Code
had same problem, replaced all egr equipment to find it was only a vaccum line. make sure all are in good shape.
