T stat housing
Old Oct 14, 2011 | 10:08 AM
joeyd61's Avatar
joeyd61
T stat housing
I have seemed to misplaced the link....does anyone have the link for the billet t stat housing??
Old Oct 14, 2011 | 10:38 AM
PaysonPSD's Avatar
PaysonPSD
Dieselsite Billet T-stat Housing
There you go.
I have never had a problem with the stock housing, just with an aftermarket t-stat o-ring.
Old Oct 14, 2011 | 10:49 AM
joeyd61's Avatar
joeyd61
Thanks...I was led to believe that you should change the housing everytime you change the T-stat
Old Oct 14, 2011 | 10:50 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
There you go.
Same here. Took 3 times to finally get the housing to quit leaking. But I now know how to do it right the first time install.
Old Oct 14, 2011 | 10:52 AM
joeyd61's Avatar
joeyd61
well okay thanks i will save my money
Old Oct 14, 2011 | 11:03 AM
PaysonPSD's Avatar
PaysonPSD
Not necessary unless it is beyond cleaning up. I just clean it up and put a coat of Rustoleum on the outside. Be sure to use an OEM o-ring for a leak free install, not that some aftermarket o-rings won't work. The cross-section of some aftermarket o-rings are slightly smaller in height and don't always seal properly. 15 ft/lbs on those three small bolts. I've never had to use any sealer for leak free install with proper size o-ring.
Old Oct 14, 2011 | 01:14 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Makes me wonder if I should sell my billet housing and keep my oem...
Old Oct 14, 2011 | 02:16 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
^^^ If you already bought it use it, I like mine and have not had a problem with it yet.
Old Oct 14, 2011 | 05:19 PM
Tailgate77478's Avatar
Tailgate77478
Love mine, bought another one for "HIS" (not installed yet).
Old Oct 14, 2011 | 05:53 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Or you can do like I did....OEM O-ring, Original housing and a little bit of black RTV. When I was done I fired it up and dared it to leak....it didn't.
I probably should have painted the housing before re-installing. I cleaned up the mating surfaces but just left the rust oxide coating alone. We hardly ever see any rust down here so I thought it looked kinda cool to have a little bit of rust somewhere on the truck....
Old Oct 14, 2011 | 07:58 PM
F350-6's Avatar
F350-6
No you don't have to change the housing every time. Only when or if it leaks. Dieselsite sells the billet housing, or the other option would be to go with a flange ring with longer bolts. Dennis sells these as wells as a few other vendors. T-Stat Housing Ring
I'm still running my factory housing. I pull it every 100k when I flush my coolant. I'll put money on my OEM one making it to at least 400,000 miles (only 20k to go).
Old Oct 14, 2011 | 08:09 PM
ToMang07's Avatar
ToMang07
I actually JUST got done installing the one from Dieselsite, and it is very much worth the money. The stock one is very thin, and mine was VERY rusted.
Old Oct 14, 2011 | 08:22 PM
PaysonPSD's Avatar
PaysonPSD
Right off the strictly diesel site "The factory housing will flex when tightened down unevenly". All you have to do is tighten it evenly and with the proper o-ring no leaks.
joegeds
Oct 29, 2020 08:28 AM
thedieselkid
Aug 1, 2011 07:42 PM
cps
13
Nov 30, 2010 09:45 AM
roushcm
Aug 5, 2010 02:00 PM
johnsjsj
Dec 19, 2008 08:27 AM
