1978 - 1996 Big Bronco
Bronco tops
Old Apr 8, 2003 | 11:19 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Bronco tops
Was wondering, are the fiberglass tops enterchangeble between 80 and 86 broncos?
Was questioned about selling a top.
Old Apr 9, 2003 | 02:41 AM
greystreak92's Avatar
greystreak92
Bronco tops
The tops are interchangable from 80-96 on all Broncos. In '92 Ford added the high-mount stop lamp, and shoulder harness seat belts that attach to the top above the side windows. So while tops from 92-96 will fit, you will need to add wiring if you want the stop lamp to work. But, if you want to swap to shoulder belts in the rear you are set!
Old Apr 10, 2003 | 10:00 AM
bbronco's Avatar
bbronco
Bronco tops
any one ever tryed to put a 90's on a 79? or the other way around?
Old Apr 10, 2003 | 11:44 AM
greystreak92
Bronco tops
Nope, they won't fit. The 78-79's are different.
