1968 F-100 Steering column
Old 10-12-2011, 05:04 PM
deerbuster's Avatar
deerbuster
deerbuster is offline
I have a gap in my column between the collar and the turn signal can housing, what am I missing? Trying to get it together.
Old 10-12-2011, 07:33 PM
williamwilliam's Avatar
williamwilliam
williamwilliam is offline
There is a slight gap between the 2 parts. There are 2 nuts, one on top and one on the bottom of the turn signal switch. Loosen those up but do not let the nut come off the bolt because its a B***H to get back into the slots!!! Push down on the collar to make sure its "seated" properly on the column and when it all the way down as far as you can get it, push down on the signal can. It should go together pretty close. Hold it there then tighten it down using the 2 bolts you loosened at the begining. Is your truck an automatic??? You may have to somehow manuever the gear shifter forward (towards you) somehow while holding down the signal canister and tighten it up all at the same time. On an automatic sometimes the gear pin inside the collar where the shifter hits the pin will actually hold the signal can back and will not let it seat properly......i know, its tricky.....its all trial and error as I had a time putting mine back together too. I hope this made sense, its hard to explain and even harder to pull off. Good luck!
Old 10-12-2011, 09:17 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
What do your cab mounts look like? If the cab mounts are shot or well on their way the cab will drop creating a gap where you speak of. It causes other issues far more important than cosmetic but let's first determine the cab mounts are good.
Old 10-12-2011, 10:25 PM
TaborCT's Avatar
TaborCT
TaborCT is offline
my cab mounts are shot. in fact i dont have any besides the replacements in the bed of the truck. no floor pans either but im still driving it. lol
Old 10-12-2011, 10:36 PM
elgemcdlf's Avatar
elgemcdlf
Be careful. You could end up with the cab falling off the frame while driving. There are only 4 bolts that hold the cab to the frame. You do have a few connecting to the front clip but if that cab decided to go the front clip mountings won't stop it. I can't say much. When I was young we would put 2x4's between the cab and frame to hold it up so we could drive it.
Old 10-12-2011, 11:57 PM
TaborCT's Avatar
TaborCT
TaborCT is offline
lol i dont drive it far. just from one yard to another lol. the storage port is in our neighbors back yard. lol
Old 10-13-2011, 06:44 AM
deerbuster's Avatar
deerbuster
Thanks, i'll give it a try tonight.
Old 10-13-2011, 06:49 AM
deerbuster's Avatar
deerbuster
Also, I have a 88 302ci in this truck with an old cruisematic tranny, having trouble finding the fluid amount with a empty converter. any ideas?
Old 10-13-2011, 08:50 AM
elgemcdlf's Avatar
elgemcdlf
Try filling it in reverse or at least letting it run in reverse for a few when it shows full in park. You could have filled the converter prior to install. I know, hind sight if 20/20.
Old 10-13-2011, 09:44 AM
deerbuster's Avatar
deerbuster
Thanks, do you know if the tranny cooling line are 5/16?
Old 10-13-2011, 11:24 AM
elgemcdlf's Avatar
elgemcdlf
They are usually 5/16" sometimes 3/8". You can make them whatever size you want. I would probably make them 3/8" and if need be step them down at the trans and radiator. It would give you a slightly more capacity. Not much but you gain ground in small ways.
Old 10-13-2011, 12:49 PM
deerbuster's Avatar
deerbuster
Thanks, i have alot of new 5/16" brake line,i'll try it
Old 10-14-2011, 05:08 AM
deerbuster's Avatar
deerbuster
Heater Cables
my heater cables seem to be binding on my 68-F100, i put all new cables and clips on. What is the proper adjustment for this? they work in the right order, but super stiff to move.
Old 10-14-2011, 07:11 AM
elgemcdlf's Avatar
elgemcdlf
Did the heater controls work smoothly and easily without the cables attached? If so them check to verify the other end of the cable connection operates without binding when the cable is disconnected. Heater control valves are good for corrosion and freezing up. They are inexpensive. If all checks ok then it is either in your routing of the cables putting them in a bind or clamped down too tight pinching the outer housing around the center.
Old 10-14-2011, 08:59 AM
deerbuster's Avatar
deerbuster
yes it works pretty smooth when its not hooked up, so ill check the other stuff. where can i find a picture of the routing of the cables?
Quick Reply: 1968 F-100 Steering column
