They will bolt in. With the exception of the inner feet. The bench has 4 bolts. One in each corner of the seat. So do EACH bucket seat. Thats 4 holes per seat. Plus what ever you mount between them. Are you seeing the problem?
I see no problem. The mounting method you described is how the Excursion captains are. Super Duty rear captains are mounted with 4 bolts per seat to a single base which then uses the same 4 mounting points as the bench seat. So, it would be a direct swap with no modifications.
Originally Posted by A/Ox4
I would guess that is true for trucks that came with the option. The 2003 model year (the OP's year) did not have the option, therefore I would not imagine there are punch outs.
MY03 offered rear captains in Lariat LE, King Ranch and Centennial Edition trim levels.
Originally Posted by Airjammer
Anyone know if Excursion seats will have the same "bolt pattern" as the F series?
Rear captains were introduced in the MY00 Lariat LE...
BTW... Good advice on the Torx Plus bits. They can really save one from alot of grief when it comes to things like seat mounting bolts and seatbelt bolts...
Must have been an unpopular option. I've never even HEARD of it. Makes me wanna pull up my carpet.
And thanks
Had them in my '00 Lariat LE and found them quite useless. Looked alright though. I much prefer the FlexFold bench that I have in the '04. So does the dog...
AGGH, So what I am understandin is that I can search for captians chairs from a superduty or an excursion??? and just look at the bolt pattern/footprint, right guys.
No, just Super Duty. Excursion captains use 4 mounting points per seat to the floor which will not work in a Super Duty. Super Duty captains are both mounted to a single base/support first, which then is mounted to the floor using the same 4 mounting points as the bench seat
I checked the 2002 brochure. Didnt see mention of rear captains chairs.
MY's '00, '01, and '02 only offered rear captains on the F-350 Lariat LE trim level. You had a choice between front captains and rear bench or quad captains. See the attached PDF for MY02 example...
