Data Link
Old Oct 11, 2011 | 12:46 PM
mrwrench's Avatar
mrwrench
Data Link
my truck doesn't have signal on data link connector , so i can't read codes . any advice ? thanks
BPofMD's Avatar
BPofMD
Veteran: Navy
Check fuses...I forget the number for the OBDII connector
Old Oct 11, 2011 | 12:52 PM
mrwrench's Avatar
mrwrench
[QUOTE=BPofMD;10908839]Check fuses...I forget the number for the OBDII connector[/QUOTE
is there a fuse for data link?
Old Oct 11, 2011 | 12:55 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Yes, does the cigarette lighter have power?
BPofMD's Avatar
BPofMD
Veteran: Navy
Data Link IS the OBDII connector. ^ is right...I forgot that lighter is on same circuit.
Old Oct 11, 2011 | 01:00 PM
mrwrench's Avatar
mrwrench
no power on cigarette lighter
Old Oct 11, 2011 | 01:05 PM
amdriven2liv
Check manual for location. I'm not sure enough about fuse number. That should fix it.
Old Oct 11, 2011 | 01:16 PM
mrwrench's Avatar
mrwrench
Fuse #13 was the problem . I got a PO299 . it happens when I crank in cold .
Old Oct 11, 2011 | 01:30 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Turbo underboost
Probable Cause[s]
Faulty Injector Control Pressure (ICP) sensor
EGR system fault
Engine mechanical condition -Low oil pressure
Faulty Turbo/Supercharger
desperado_18_2000
Jul 2, 2018 07:58 AM
HughLee
Mar 27, 2017 09:00 PM
FlatlanderKW
Aug 4, 2010 04:18 PM
Dutch Steve
1997 - 2003 F150
Mar 10, 2005 07:20 AM
canarycary
15
Apr 8, 2004 10:59 PM
