Carter YFA Idle Mixture screw
Old Oct 11, 2011 | 07:59 AM
nlareau's Avatar
nlareau
If I close the idle mixture screw entirely, should the engine shut down? Mine just idles rough but keeps running.
When I look at the screw then pointed end has a small ridge in it. If you run a thumbnail over it, you can tell there is a definite small ridge. I've ordered a replacement, but before I change it out, am I right in assuming this point should taper smoothly?
Old Oct 11, 2011 | 09:46 PM
fmc400's Avatar
fmc400
MSEE
If you turn the mixture screw all the way in, the engine should theoretically stall because you're cutting off the idle circuit from the intake stream.
The idle mixture screw should be smooth and taper to a point.
DAT2109
Apr 4, 2012 09:12 AM
silver777
Nov 2, 2010 05:21 PM
Jag Red 54
Aug 17, 2004 08:03 PM
Jag Red 54
Aug 17, 2004 03:56 PM
killer4x4
Jul 9, 2001 01:35 PM
