Replaced CKP sensor, and today...
Old Oct 10, 2011 | 11:57 AM
Carolina Rig's Avatar
Carolina Rig
I think this is unrelated to having replaced the CKP sensor this weekend, but I need to ask anyway.
I replaced the CKP sensor on Sunday. I only replaced it because there was a little oil getting past the o-ring. The old sensor was fine, and since I had a whole new unit, I repaced the unit (not just the o-ring).
Started it up to go to work this morning and when I drive away I hear a hissing noise. Sounds like I'm blowing air. Truck was fine when I parked it on Friday, and it sat all weekend.
Is there any reason that changing the CKP sensor might cause something with the turbo to get outta whack (electrically, VGT or something)?
I've got dieselsite intercooler boots and they're fine and tight; while it's running, with the hood up, I can hear the hissing and it sounds like it's coming from the turbocharger. I also noticed some oil on the outside of the turbo; but so far from feeling around, all the charge tubes/hoses are fine. Boost gauge seems to be showing normal boost and it doesn't feel any weaker. No CELs.
Any ideas?
Thanks
Old Oct 10, 2011 | 12:00 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Exhaust leak in the downtube ????
Old Oct 10, 2011 | 01:47 PM
Carolina Rig
I'm gonna check that tonight - It does sound like it could be.
Meanwhile, I'll post what I find.
Old Oct 11, 2011 | 06:57 AM
Carolina Rig
Okay, I was wrong.
got home and upon closer inspection the boot at the compressor outlet had slowly worked its way off at the bottom and was leaking air.
I like a cheap repair like that.
JaySVX
Dec 7, 2018 10:47 AM
superman79
23
Apr 6, 2015 02:56 PM
dmonell
Nov 23, 2013 10:58 AM
Forest
Nov 14, 2011 10:08 AM
6LPSD
Feb 28, 2009 10:49 AM
