Sponsored by: Real Truck
F250 stall
Old Oct 9, 2011 | 11:43 PM
Psychotrucker's Avatar
Psychotrucker
F250 stall
I have a 02 f250, it starts fine, drives fine, but when you come to a stop it cuts off. Starts again, can keep running by keeping foot on accel. Solus scanner gets speed sensor code every time it cuts off, been replaced. Any suggestions will be appreciated. Thanks Tim I
Old Oct 10, 2011 | 12:49 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
CPS anyone?
Old Oct 10, 2011 | 12:59 AM
PTL.PARKS's Avatar
PTL.PARKS
LITTLE MORE INFO WHAT MOTOR IF ITS THE 5.4 CHECK YOUR CONNECTION ON THE MASS AIRFLOW SENSOR I HAD THE SAME PROBLEM ONLY TO FIN OUT THAT THE HARNESS TO THE SENSOR WAS BAD
SOORY ABOUT THE CAP LOCK IM NOT YELLIN
Old Oct 10, 2011 | 03:55 AM
1973Ford2004's Avatar
1973Ford2004
I would check live feed on your scanner. I had same problem it was a misfire but didn't happen enough to pop a code, I changed the COP and runs great.
Old Oct 10, 2011 | 08:37 AM
jh818's Avatar
jh818
If it does this while the engine is cold and it's a gasser then could be your IAC valve.
Or...TPS going bad?
Old Oct 10, 2011 | 11:56 PM
Psychotrucker
Sorry, yes it is a 5.4, the iac is new, and I am going to check the tps , the harness, and the mass air when I get home. Thanks a bunch for the suggestions, Is there anyone in richmond area good with this sort of problem, maybe we can get together to chat. Im in a bind, just had back surgeryand hunting season is coming fast. Tim
Jehan Hormazdi
May 20, 2019 09:21 PM
anthony mayer
Aug 31, 2013 02:32 PM
82fordguy
1983 - 2012 Ranger & B-Series
Jul 25, 2009 12:16 PM
John_1953
Oct 14, 2006 09:46 PM
