Misfire Cured?
Old Oct 8, 2011 | 06:52 PM
fireftnford's Avatar
fireftnford
Misfire Cured?
My 2005 F150 crew had a misfire when under wot. I had been putting off the diagnosis fee for months, but I finally bit the bullet. Found out my number 3 coil was bad and the number 3 cylinder was dropping out. Dealer swapped out coil and truck runs better now. Still have to get plugs done. Truck has 88000 miles. Already had the cat replaced and didn't want to go through that again.
Old Oct 8, 2011 | 07:11 PM
shorebird's Avatar
shorebird
Who wants to tell him that he could have had the codes read for free at most parts stores?
Old Oct 11, 2011 | 08:04 PM
fireftnford
Yeah, I know. This is just something I have been puting off. I just wanted it fixed.
Old Oct 12, 2011 | 07:50 PM
cb_13's Avatar
cb_13
Having the code pulled and having it diagnosed are two very different things. A good shop will stand behind their diagnostics.
Old Oct 12, 2011 | 08:17 PM
ford390gashog's Avatar
ford390gashog
When you do the plugs make sure you use silicone grease on the boots to prevent moisture and burn through of the rubber.
Old Oct 13, 2011 | 03:41 PM
fireftnford
When they put it on the machine the number 3 coil was dead. I don't know how I didn't blow her up.it was running like crap, for a long time. I have full confidence in the dealership where I get my service done. I am more than likely not going to do the plugs myself.
EntoMan
Feb 13, 2018 10:53 AM
TheGageinator
2004 - 2008 F150
Mar 7, 2014 12:14 PM
jkait1982
2004 - 2008 F150
Mar 3, 2014 05:18 PM
aginc
Escape & Escape Hybrid
Feb 20, 2013 07:11 AM
wvaughn
2004 - 2008 F150
Oct 10, 2012 08:14 PM
