Off topic but no answer on other area
1993 ford explorer starter works fine it starts and runs but the solenoid power wire will not stop supplying power replaced relay on fender still not working right ignition in column is messed up but if you try slowly turning it back it just shuts off any idea?
well at least its running for now. if you want it to get back to OEM, i would start with a new ignition switch, and if that doesn't do it then i would be looking for a short in the wire harness - but that may be an all day thing to find the problem, thats up to you and the owner to decide if its worth doing
Julie's77
10-02-2018 12:58 PM
William McCoy
02-04-2012 04:06 PM
77h0t_r0d_wrecker
02-22-2011 10:11 AM
