Ignition problems
Old Oct 8, 2011 | 01:48 PM
FORDtillITkillsME's Avatar
FORDtillITkillsME
Cool Ignition problems
no spark from the coil to the distributer, any suggestions? checked everything except the ECM and replaced everything but the ECM and ICM on the distributer. been banging head against the wall for a MINUTE!!!
Old Oct 8, 2011 | 01:59 PM
Slip ford man's Avatar
Slip ford man
Search for TFI and PIP circuit, common problem...best changed together at the same time.
Old Oct 8, 2011 | 02:04 PM
FORDtillITkillsME
i changed the magnetic p/u in the distributer and still nothing. been reading the book and it says if everything checks out then it's the ICM. what do you think?
Old Oct 8, 2011 | 02:09 PM
Slip ford man
Many times those re-manufactured distributors come in the box with a bad pick up...is that what you put in, also, did you install a new TFI?
Old Oct 8, 2011 | 02:14 PM
FORDtillITkillsME
no sir. just replaced the pickup in the distributer. do you mean the ignition control module mounted on the distributer when you are talking about the TFI?
Old Oct 8, 2011 | 02:21 PM
Slip ford man
Yes, that's it
Old Oct 8, 2011 | 02:22 PM
FORDtillITkillsME
no i haven't but i did all the resistance checks and it checked out. could it still be bad?
Old Oct 8, 2011 | 02:30 PM
Slip ford man
Well it passed, try unplugging the computer and see if you get spark
Old Oct 8, 2011 | 02:32 PM
FORDtillITkillsME
I'll give it a shot. God knows I've tried everything else.
Old Oct 8, 2011 | 02:39 PM
FORDtillITkillsME
nope. nothing
Old Oct 8, 2011 | 02:40 PM
Slip ford man
Read through Subfords post here https://www.ford-trucks.com/forums/1...ark-issue.html
Old Oct 8, 2011 | 02:48 PM
FORDtillITkillsME
Thank you! That was helpful. I'm hoping that info applies to my 5.0 the same as it does for the 7.5
Old Oct 8, 2011 | 03:32 PM
Slip ford man
Yea most likely the pins are different...pull your codes, see if the PIP is listed...what year is she
Old Oct 8, 2011 | 03:57 PM
FORDtillITkillsME
Late 89 but sold as a 1990
Old Oct 8, 2011 | 04:00 PM
FORDtillITkillsME
Disconnected the computer and got spark! Guess I'm either chasing a ground or buying a computer. How do you tell what model computer you have?
