Can't get turbo off
Old Oct 8, 2011 | 01:22 PM
RickBraden's Avatar
RickBraden
Can't get turbo off
Hello. I down loaded the Turbo Removal pdf from this site & I have everything disconnected. It took forever to find the bolt in the back, Now with all 3 bolts out & exhaust in & out disconnected, along with oil feed off & electrical disconnected, I don't know if I should tap on it or what to do. I can't afford to break anything.
FYI, I'm going to install egr cooler delete etc. Thanks for any help.
Old Oct 8, 2011 | 01:27 PM
dschuffert's Avatar
dschuffert
The first time I took mine off I had to tap it with a rubber mallet. The oil drain pipe is probably holding it. Try tapping it up to get the oil drain pipe loose / free. Mine came right off after that (assuming everything else is disconnected).
Old Oct 8, 2011 | 01:40 PM
NewToDiesels's Avatar
NewToDiesels
Yep, just give a good yank straight up while grabbing the inlet. May need a light tap from a mallet.
Old Oct 8, 2011 | 02:15 PM
Fallguy2004's Avatar
Fallguy2004
I had to use a small pry bar to get it to move
Old Oct 8, 2011 | 03:07 PM
RickBraden's Avatar
RickBraden
Thanks for the tip. I will do that when I get out of work.
Old Oct 8, 2011 | 03:26 PM
High Binder's Avatar
High Binder
Use a pry-bar across the passenger side valve cover and under the turbo.
Old Oct 8, 2011 | 04:11 PM
RickBraden's Avatar
RickBraden
I'm looking at Turbo Removal & Installation pdf now & can't understand why it tells you in:
Step 11-Loosen the exhaust inlet pipe-to-EGR cooler clamp.
#12-Loosen the LH exhaust inlet pipe-to-exhaust manifold nuts.
#13-Loosen the RH exhaust inlet pipe-to-exhaust manifold nuts.
How does help the removal of turbo? I must be missing something. Thanks.
Old Oct 8, 2011 | 04:14 PM
NewToDiesels
It just gives the pipes room to roam. Especially helpful on installation when getting everything lined up again.
Old Oct 8, 2011 | 04:17 PM
cheezit's Avatar
cheezit
close... drives side prybar goes under turbo and use intake for levrage
Old Oct 8, 2011 | 06:40 PM
Maxium4x4's Avatar
Maxium4x4
Always a good idea if you live in the salt states, to remove and replace the 4 up-pipe bolts and nuts. If all the bolts are removed and pipes loose, put some effort into it.....
Old Oct 8, 2011 | 06:43 PM
RickBraden's Avatar
RickBraden
I got it off & happy as can be. I pryed where cheezit said & great results. I had to take the heat shield off of turbo (2 little bolts I think) to be able to raise it up enough. Thank you everybody for offering help. Next I have a quick question. I've head something last year about some plastic oil/fuel screen comming apart & people were replacing with s.s. I think can anyone help me here.
I am going to do the egr cooler delete, I have ford upgraded oil cooler. I have to study more to see what has to come off engine for this. Any links would help. Good night, Rick
Old Oct 8, 2011 | 07:00 PM
BLADE35's Avatar
BLADE35
intake manafold needs to come off
https://www.ford-trucks.com/ford-man...%20removal.pdf
The scren that comes apart that you are refering to sits under th oil cooler you will see it when you pull it out
Old Oct 8, 2011 | 07:02 PM
NewToDiesels
Are you referring to the IPR valve? It's on your HPOP cover. You'll want to inspect and upgrade the the latest screen.
Old Oct 8, 2011 | 07:05 PM
wulfman's Avatar
wulfman
The screen the blade is talking about should come with your new oil cooler.
Old Oct 8, 2011 | 07:10 PM
NewToDiesels
Rick,
This thread should help you with some tidbits...
https://www.ford-trucks.com/forums/9...uctions-2.html
