Looking for recommendations for a Pillar Gauge cluster on my '04 F350 DRW 2 wheel drive.
I know Fuel Pressure is #1, but what else?
Boost maybe? or anything else.
Also a brand of gauge for the cluster. Any kits that are already out there with multiple gauges.
Is there a ScanGuage that does Fuel Pressure and Boost?
Also is there a scan tool out there that is affordable that reads the codes from diesels? Not the little cheap "Check Engine Light" ones at the auto parts stores, but one that I can use that will show other codes that do not come up on those.
Will the Scan Gauge 2 do this?
I haven't had mine in long enough (less than a week) to give a fair comment...but I like how it looks in the truck. He pre-painted the pillar before shipment...the color match is so close I think it's just the difference in new paint & older sun faded. If you do go ahead and order from Clay @ RiffRaff, you need to make sure you specify your using 'em on a 6.0L truck. The fuel pressure test port on the 7.3L is completely different...and from talking to him, until now most of his Ford business was 7.3L crowd. I can say this, his customer service is outstanding
Glowshift makes a 4 gauge pod kit. I think it's like 200 $ an that includes gauges. I don't have one , so I can't say if they r good or not. Have read in here people who have them an like them. The ones I read didn't have any problems out of them. I'm soon goin to get them for my truck.
just got mine today. $270-ish shipped for 4 gauges with all stuff needed to install
they look great and I can't wait to install. I also bought a fuel rail adapter, but that isn't something you have to buy. I just did to make the install easier
ZH do the RiffRaff gauges (specifically fuel gauge) come with the sending unit and test port adapter?
Yes, you just need to specify that your a 6.0L truck since the 7.3L (most of his business) has a different size port. Other than that...they come with everything you need...other than your labor. If your doing the pyrometer & boost you'll need the drill & tap since they're not included. Think you'll need a "R" bit, I'll have to go look on the tap. But you can also buy that from Clay if your in a spending mood
If you don't have a scangauge ii I would recommend getting one. I'm new to the 6.0's was recommend the scanguage and I love mine very easy to use also. I picked mine up off eBay for $159. That's about the going rate that I found for them
I have the glowshift three gauge pillar fuel 0-100psi, boost, and egt along with scan gauge II they look good and pillar is a perfect match on the color. The pillar, gauges, and fuel sender 242$ shipped to my door. Picked up my scangauge from autozone 159$ had it next day
Just noticed the Fuel Pressure Gauge is only 0-30 psi. I was thinking the 6.0L fuel pressure was supposed to be around 45-55 psi. Am I wrong on this?
edit:
That gauge won't work. You need the 0-100 psi gauge. contact the seller and see if they can change your order to the higher psi fuel pressure
I love my setup. I spent 3-4 hours last night soldering and running wires for mine. Ran out of wire, so have to pick up some today and finish the install
It does come with a 100PSI Gauge. Whew.. Ebay Lister said he copied and pasted it wrong. Paid $210 for a 3 gauge color matched pillar cluster with a Pyro, Boost and 100 PSI Fuel Pressure gauge. Also as stated, I bought a ScanGaugeII.
You'll def be satisfied and have an ease of mind with your selection
