6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 F350 Deisel no compression #6
Old Oct 5, 2011 | 06:30 PM
cfvwd's Avatar
cfvwd
Just had my friends F350 into the dealer because it was making a noise and seemed like it had 1 cylinder not fireing.
Dealer says no compression on #6 so we towed it home and took the vlve cover off and guess what no rocker arm on #6 intake valves.
So called the dealed and he said the rocker arm was broken so we went and got the arm, its not broken but he got it off with out taking the fuel rail off.
Intake valves both can be pushed in and the push rod is not bent.
Has any one had this problem could the ball that the rocker arm pivots on have broken?
Suggestions please.
Chuck
Old Oct 5, 2011 | 06:38 PM
powerstroke72's Avatar
powerstroke72
Moved to correct forum.
Old Oct 5, 2011 | 07:05 PM
senix's Avatar
senix
there have been some rocker arm failures. Not common but has happened. Speculation is extended oil change intervals and fuel dillution as contributing to some of this issue.
Old Oct 5, 2011 | 10:07 PM
golfmedik's Avatar
golfmedik
Just happened on my work truck at 92k. The plastic clip on the arm breaks and leads to the failure.
B85
Apr 18, 2016 02:24 AM
Thinlizzy13
Oct 11, 2015 03:47 PM
low_life
Modular V8 (4.6L, 5.4L)
Aug 9, 2005 02:57 PM
WALJON
Dec 24, 2003 03:25 PM
