air pump?
Old Oct 3, 2011 | 01:18 PM
21411's Avatar
21411
Question air pump?
i bought a 351w out of a 72 galixie. on the pass. side exhaust manifold there's a cover that looks like a hose should be connected? the hose would route to the front.
what is this? and i'm assuming since its a carb and going in a 64 f100 i just need to hook up gas, coil, starter, and radiator to run. right?
just don't want to hurt the engine but its my first go around so i'd like to know. thanks and sorry i didn't use the search, didn't know what to search for.
Old Oct 3, 2011 | 07:41 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
There should be a hose to the air cleaner to bring heated air when the engine is cold. Connects to the stock breather, a vacuum pot controls the damper inside.
Works with the choke to make the vehicle drive better until the engine is up to temp. If you've got the stock breather it's definitely worth keeping intact.
Old Oct 3, 2011 | 08:41 PM
21411's Avatar
21411
Its just that piece around the manifold then the carb. No air cleaner, no hose. so ill just have to work the choke till i get the 4 barrel with the auto choke?
Thanks for the help.
Bluethunder3320
Mar 3, 2013 08:12 PM
zenmaster
36
Dec 4, 2008 11:29 AM
cleveland
16
Mar 10, 2008 09:30 PM
rjaywhit
23
May 23, 2007 11:38 PM
jolvh2
May 2, 2003 04:01 AM
