Yeah I know along with the heat the crop around here is not real good as a far as sugar beets go.
Originally Posted by DieselCamper01
I didn't realize heat was a problem for harvesting sugar beets.
The weather isn't a bad thing for the beets at this point but it is harvesting them that is the problem because crystal sugar can't pile them if they are too hot otherwise they will rot. You also can't lift beets when it is too cold because then they get frosty. They are a pain in the keister.
Exactly and basically the same with potatoes as far as the hot and cold goes. But the money you make off them usually tends to make the problems not so bad!
Yup. The crop is pretty pathetic this year though. It takes a round and half of a half section field to get the truck loaded when it should take 3/4 or a round.
Got the siding back on the house, now to tackle the inside.
Originally Posted by fordpower88
Yeah I quit with the AF in the lines long a ago for that reason also. I have a fitting that screw into the lines and you can just put your air blower from your air compressor up to them and blow the water out. I should grab some to give you guys. I have a ton of them for my washers.
Yeah that is also correct and don't forget to turn that valve down there also!
