1978 - 1996 Big Bronco
TP sensor bad, code 63
Old Apr 7, 2003 | 05:35 PM
Red_EB_Bronco's Avatar
Red_EB_Bronco
Question TP sensor bad, code 63
I finally took the bronco in to get some codes, it turns out I only got 1 code which was 63 and they told me that the "TP Sensor circuit below minumum voltage" does that mean I have to change the TPS? ($28.99) or does it mean there is an electrical problem?
thanks for all your help.
Old Apr 7, 2003 | 07:59 PM
thelonerangerxlt's Avatar
thelonerangerxlt
RedEB, that is indeed the cause of a code 63. Are you having drivability problems? A few of those TPS's were adjustable, so check yours to see if it adjusts when the screws are loosened.
You can also check the TPS output with a voltmeter, if you want to go to the trouble. But after 15 or so years, it probably needs replacing, and will probably run a lot better with a new one......
Old Apr 8, 2003 | 08:55 AM
Red_EB_Bronco
idle problems is all,
Old Apr 8, 2003 | 09:52 AM
thelonerangerxlt
Since you're having idle problems, and getting a code 63, I would just replace the TPS. It should idle/run much better with a new one.
The TPS is simply a variable resistor, and it does wear out over time.
Old Apr 8, 2003 | 07:28 PM
Red_EB_Bronco
do you really have to pull the damn TB off to get to the TPS? this is messed up, I have 1 more bolt to go and I'm there and it is stripped which = stress on me. this should only be a 30 minute job errr
Old Apr 8, 2003 | 07:31 PM
Red_EB_Bronco
