transmission swap
Old Apr 7, 2003 | 05:35 PM
scott mills's Avatar
scott mills
transmission swap
I have an 1988 Ford F150 (302) with an 4 speed automatic overdrive transmission. Is there a website that will tell me what other years and ford vehicles used this same transmission? I found a transmission in a 1990 Ford thunderbird will it fit?
Old Apr 7, 2003 | 06:36 PM
madman666's Avatar
madman666
transmission swap
If your truck is two wheel drive, and your Trans is the AOD and if the t-bird also has the AOD it should work.
Also watch out the T-bird may have the AOD-E this is electronically controlled
It wont work then if it is.
Sorry don’t know of a website
If you look at the door sticker on your truck and car for the transmission code, post it here and we'll tell you what transmissions they have.
