Sponsored by: Kumho
Ball joints/tierod ends
Old Sep 29, 2011 | 04:24 PM
boss1982's Avatar
boss1982
Does anyone know if you can drill, tap, and install grease fittings into OEM ball joints and/or tie rod ends? I've used the needle thru the dust boot but that doesn't get inside the piece where the movement and wear & tear actually occurs.
Old Sep 29, 2011 | 09:50 PM
elgemcdlf's Avatar
elgemcdlf
They are filled when built which creates a problem for your idea. Once you pop through with the drill bit a bunch of metal shavings are going in with it. The grease will grab them and the bit will come out clean. Since you have no way to get the grease or shavings out I think you will be creating a larger problem. These are usually inexpensive pieces to replace.
Old Sep 29, 2011 | 09:53 PM
Listor's Avatar
Listor
Originally Posted by elgemcdlf
They are filled when built which creates a problem for your idea. Once you pop through with the drill bit a bunck of metal shavings are going in with it. The grease will grab them and the bit come out clean. Since you have no way too get the grease or shavings out I think you will be creating a larger problem. These are usually inexpensive pieces to replace.
Agreed, you can replace them fairly cheap , 200 bucks isn't alot considering the issues you may cause
fightlivefree
Jan 5, 2016 10:33 PM
fidge1
Apr 5, 2011 07:36 AM
bkr2
Jul 17, 2008 12:31 PM
m@m
2004 - 2008 F150
Dec 8, 2007 08:41 PM
marilyn
1983 - 2012 Ranger & B-Series
Aug 12, 2007 08:22 AM
