Camper battery charging - With a 6.0
Scotts method looks pretty good, and would be a good option.
Another way to look at it is that your truck already has an isolator built in. Meaning, it already isolates the trailer connection unless the alternator is running. But it is not large enough in ampacity to be an effective charger. That is a classic situation for using an isolation relay. Instead of using the ignition circuit to control a voltage sensitive relay, why not just use the trailer charge circuit to turn the isolator on/off? The relay Scott suggested would work fine for this as well.
What do you mean by using the trailer charge circuit to turn the isolator on off, do you mean instead of using the ignition relay?
The advantage this has, is that the truck does not energize that wire to pin 4 until the truck is running. That is different than energizing it when the ignition is simply turned on.
Then all you need is a HEAVY wire between your truck battery and the camper battery. I would say about an #0 sized wire. You should also put a fusible link in the line to protect that wire.
Yes. Find the wire that goes to pin 4 on your bumper plug. That is the +12V wire, which is the battery charge wire. Use that wire to control the isolator relay, like the one Scott linked to.
There is no switching back and forth. That is not how it works. When your truck is running, the truck battery and the camper battery are connected together, and they equalize. When the truck is shut off, they are separated.
Converter only connected when loading the camper using the electric jacks. This way I can connect the truck while still using the house power to raise or lower.
The reverse is also true, that the battery voltage will not instantly drop to 12.7v to open the solenoid, so there will be a delay there depending on your load.
This might come in handy for wire size selection (for this or other projects):
Amps column= Copper conductor,Polyethylene/Neoprene/Polyurethane/Polyvinylchloride insulation.
Single Conductor in Free Air 30°C Ambient Temp.noncontinuous load.
Continuous Amps Column= Copper conductor TW-60C insulation. updated to 2011 NEC on 04/03/2011.
Gauge........AMPS..........Continuous
30...............2.................AMPS
28...............3
26...............4
24...............6
22...............8
20..............10
18..............15
16..............19
14..............27..............<1-12
12..............36...............13-16
10..............47...............17-24
8................65...............25-32
6................95...............33-44
4...............125..............45-56
3..................................57-68
2...............170..............69-76
1..................................77-84
1/0...............................85-100
2/0..............................101-116
3/0..............................117-132
4/0..............................133-157
250kcmil.......................158-172
300kcmil.......................173-
Dang, My "dot typing finger" just got a cramp!
28...............3
26...............4
24...............6
22...............8
20..............10
18..............15
16..............19
Another idea that might work for you is installing a roof mounted solar system to keep your batteries charged. I would think you could use it in conjunction with the truck's charging system, while in transit, to assist with bringing batteries back up quicker after the night draw. They would also charge and keep the batts up during daytime camping so batts are good before each night on multiple day camping stays. There are many systems to choose from. The bigger the system, the more efficient and better the results.
I do a lot of dry camping and have 6 large batteries on board. Main bank is 4 - 6 volts and a couple 12's as backup. It can get awful cold on a hunting trip and the furnace is the biggest killer of batts. What I've done in the past when I'm way down on power is hookup my truck with jumper cables to my main bank and let it run. I know this isn't the proper way but there are times when I'm deep in the woods and have to improvise.
On my 96 I had an isolator and a large wire(I think 00) run to the back bumper. I used to plug my dump trailer into it and I could also plug my camper batteries into it and run the truck to charge. Didn't do that with the 04 though.
Since then I've added solar which helps but if it's cold the batts can still get run down low and 100 watts of solar won't bring them up fast enough.
BFWF350
2017+ Super Duty
31
07-07-2023 11:26 PM
884x4broncoII
05-02-2008 10:18 AM
coplin
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-06-2007 12:59 AM
Sycostang67
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
06-07-2004 10:46 AM
