1978 - 1996 Big Bronco
Engine Computer
Old Apr 7, 2003 | 12:13 PM
bradleyj's Avatar
bradleyj
Engine Computer
If anyone out there has a 93 pickup or big Bronco with a 351W and E4OD tranny (the one with the overdrive on/off button on the shift lever), I'm looking for some help. I've got a 93 Bronco with a 302 that I want to put a 351W in. I need to change the computer since the firing order on the two engines are different (among other things). There are several model #'s of engine computers available for this engine and model year, but I can't figure out which one I should buy. If anyone has this year truck, engine & tranny combo, I'd appreciate it if you could let me know the model # of your computer. If you have a California or high altitude model, that won't help me. The number should be on a label on the computer which is on the firewall inside the engine compartment in front of the driver's seat. It should begin with "F2TF-". Thanks a lot.
Old Apr 7, 2003 | 12:26 PM
Wakeboarder141's Avatar
Wakeboarder141
Engine Computer
I have this combination and if I am reading the right thing the model number is E7DF-12A297-A1A. Hope this helps.
