Should I Get an F-250 with V-10
#46
Man thats too bad you just missed it. I was hoping for your sake your 07' had a later build date. At least you'll have a nice truck with an engine warrenty even if it cost you an arm and leg for it.
#47
I'm not sure if any manufacturer is better than any other. Some people swear by Fords, others Chevy or Dodge. All have their problems (and the 6.0 had plenty but some never had problems). Shake-n-Bake is giving you some good info to look into....although hard to prove it was the fault of a repair. Also if it's out of warranty I'm not sure Ford is obligated to do much of anything, sorry man not trying to be against you but it is what it is. I'm currently looking all over the truck I purchased in June because the warranty is up next july. Already had a manifold replaced, GEM issues, tranny dipstick and tube replaced, and this is a truck with only 27k mi on the clock! But after July 2012 my V10 could blow and then its on my dime. Just the joys of ownership I guess.
I still believe that any high mileage vehicle is prone to issues. For example I was lucky enough to acquire a car from a family member for commuting to work and back. As soon as I started driving it a wheel bearing went, then it needed new brakes, and now its making an awful noise from the front end....it has 111,000 miles on it. I drove it before it was given to me and it was fine. Things just happen sometimes and I know the problems are not some expensive motor replacement. The car was free so I'm not complaining. I just would never buy anything with more than 50,000 miles I dont care what they say about diesel motors lasting. Wearable parts are well wearable and the more miles the more wear. Again I'm not going against you and wish things could turn out better. At least your motor has a new warranty!
#48
I thought so. My advise is still the same, have every reliability fix (even 3rd party) made to the engine, no performance changes, just reliability. Then sell the truck before it warranty on this engine runs out. You might recall I bought the 08-F350 this spring, I went with the V10 'cause it's so bullet proof. This engine has stood the test of time, first shipped in 98 (for Fleet sales only), then in 99 for everyone. It's still being sold (although not the vehicles most customers buy) If I was to buy in a few years, I would look at the current 6.7 L, I have hopes that this one will be plagued with fewer problems then the 6.0 or 6.4. My Theory (TM, with no proof at all), is that Ford decided that the 7.3L replacement engine needed to have power and better fuel economy. Navistar delivered the 6.0 engine, which proved so troublesome, Ford ordered a new engine for the new emissions standards (rather then just upgrading the 6.0 to meet the standards. But even the 6.4 had issues (besides the legal issues between Ford and Navistar). So Ford came up with the 6.7, returning to the larger block engine. TTFN Ralph
#49
Looks like 5 injectors were replaced recently. 2 in April and 3 in July.
I would find out if the written Ford procedure says to replace the glow plug in the cylinder where a known injector failure occurred.
Service records also say that a compression test was performed in July. The procedure to check compression involves removing the glow plugs....just saying...
Thanks!
#50
Bob G. Still has his '00 V-10 and its running fine. I should have kept Bruiser, my '99 7.3 with 180,000 trouble free miles. )c:
#51
Thank you!
Hunter
#52
I owned a 99' F-350 Supercab Lariat (SRW) V-10 until two months ago. It had 212,000 miles at time of trade in. The V-10 always worked great, but over the last two years I owned it it started having an electrical gremlin that I just couldn't overcome. It was at the local Ford Dealer for 2 months and they were pulling their hair out, had the regional engineer look at it a few time too. They threw parts at it and in the end wanted me to pay for everything they did (New ECU, MAF, Harmonic Balancer, TPS, Lower Engine Wiring Harness, Crank Position Sensor, a whole mess of Vacuum Hoses, etc). Ford Customer Service convinced the local Dealer that they didn't fix anything so I wasn't on the hook for the big bill. The engine would slowly lose power and start shutting down each coil pack and injector, sort of a cascade until it stalled. Just like it ran out of gas. Simply turn the truck off and restart it and you were off for another 100 miles or so until it started all over again. In the end an old ambulance mechaninc suggested that I look at the coil packs, weird as it was. I bought 10 new ones and though my wife was going to divorce me...but the problem went away...for about 12 months. The Gen 1 V-10s had a small trouble code loop that didn't supply information in real time for some things. The newer V-10s are much easier to troubleshoot as I understand it, having a much greater capacity ECU and wiring harness. I hope your dealer finds that they were possibly responsible and pay the bill. My time with the V-10 was great. I now have an 08' with the PSD. I hope I get as many miles out of it. I do love the MPG increase...
Best of luck,
Clint
Best of luck,
Clint
#53
You might argue that the EGR cooler failure weakened the glow plug by thermal shock, or that the glow plug was overtightened causing it's failure, or just pay with visa and claim consumer fraud as Ford should have reimbursed you under warranty!
Jim & fat (anxious to meet Cooper one day) Monty
#54
First Cooper would love to meet fat Monty <g> Ford won't reimburse me because the warranty ran out a month before the glow plug broke and destroyed the engine.
Hunter
#55
Dang, that's an awful deal. For 14k though, you could probably drop in a 12v cummins and have some cash left; call me crazy, but if you could get away emissions wise with having an older engine swapped in, I'd do it in a heartbeat.
I'm on my 2nd v10, and both of them combined didn't add up to 14k; but they did the job, and they both have over 100k miles...
The other option, and might be worth looking into unless you gave the dealer the go ahead already, is parting out your truck and getting as much money as you can out of it, then getting something else. You'd be surprised how much some things (like a set of leather seats or a tailgate for example) go for.
#56
#57
Hope you have much better luck with this one! Does this engine come with a warranty? If so, how long? If not, did you have them do the must-haves for the 6.0? The head studs, oil cooler, egr, etc?
#58
#60
Right now you have a truck with a new engine that has a warranty, I would keep it and use it. The V-10 doesn't have much warranty left.
On the other hand, it sounds like you are pretty certain about getting rid of your current truck. If that's the decision you make, the V-10 is a great engine and I'm sure you will be happy with it.
