Bronco II Ford Bronco II
Remove Transmission
Old Apr 7, 2003 | 11:35 AM
diver1dude's Avatar
diver1dude
Unhappy Remove Transmission
Do you really have to remove the crossover exhaust and the transfer case on an 86 BII, 2.9L manual transmission to get at the clutch? How much clearance is required to remove the transmission-how high does to BII have to be raised?
Old Apr 7, 2003 | 02:51 PM
matthews_56's Avatar
matthews_56
Remove Transmission
No, you should not have to remove any of the exhaust, assuming it's all stock. It may however make things easier. There is enough clearance to get it out (I've done it). You don't have to remove the Transfer Case if you don't want to, but it does make life easier if you remove it, due to weight and balance.
Old Apr 7, 2003 | 05:45 PM
diver1dude's Avatar
diver1dude
Remove Transmission
OK, thanks. My repair manual said to remove the cross over exhaust (at the manifolds). It looks like there is room to get it (trans) out and over without removing.
After looking at the transfer case, it looks to be pretty easy to get off.
Old Apr 9, 2003 | 02:13 PM
matthews_56
Remove Transmission
No problem,
The hardest part about the removal of the T-case would be the top bolt. I think there are 5 all together. Anyway the top one will take about 10 minutes as you can't get more than an 8th of a turn. It sucks, but so does removing the exhaust.
Shanook9080
Bronco II
May 19, 2014 02:46 PM
airshac
Bronco II
Feb 6, 2009 06:46 PM
BII Plow Truck
Bronco II
13
Sep 14, 2006 10:30 PM
Steven@nd
Jul 19, 2004 01:58 PM
bII2904
Bronco II
Nov 4, 2003 07:41 PM
