towing advice
Old Sep 27, 2011 | 01:02 PM
94diF350's Avatar
94diF350
towing advice
I have a 1986 peterbilt big hood with a 3406b cat engine with a small flat top sleeper... this is going to be a pulling truck in the spring....wha I'm wanting to know is with the correct gooseneck do you guys believe I might beable to trailer this with my ford
Old Sep 27, 2011 | 01:20 PM
Neal 97 250's Avatar
Neal 97 250
I would not try it. That is a heavy truck. I am guessing around 22,000 - 25,000 lbs.
Our trucks are not designed to haul that weight.
I have pulled an over loaded rig around the lot trying to pull start it but it took 4WD. It was close to 90,000 lbs.
There is no way I would try over 20,000 on the road.
Old Sep 27, 2011 | 07:35 PM
94diF350's Avatar
94diF350
The tractor it self is on a diet and rings in at about 12,500lbs.. I've had 17k of round bale on it I was jut wondering if anybody ever attempted it due to the height..
Old Sep 29, 2011 | 02:44 PM
Neal 97 250
Just be sure it is less than 13' 6".
That is DOT legal height. Watch trees on the back roads.
You may be alright otherwise.
Gr0ve
2015 - 2020 F150
Apr 25, 2018 08:29 PM
MC_Greenmachine
Large Truck
Oct 10, 2016 10:15 PM
volksjr
1997 - 2003 F150
Apr 7, 2011 06:30 PM
duckhead4life
All Things Towing
Dec 13, 2002 09:48 PM
LIKENIT
Car/truck Buying Advice
Mar 10, 2002 06:37 PM
