I have a new F350, Larriot, V10, 3.73 LS, auto, 4WD, crew cab, srw, swb truck which I plan to use to pull my enclosed trailer and race car. Probably around 7000 lbs.
While the set up I have should be fine for the load I am towing, I was curious if the front and rear diff gears can be changed to the 4.30s.
I bought this truck off the lot as it had everything I wanted except the 4.30 gears. now I am curious does Ford sell the gear sets and can I get the swap done. If it is do-able... how much and I looking at?
