Another lift/level question
Old Sep 26, 2011 | 01:27 PM
aquasport17's Avatar
aquasport17
Dear forum,
I recently traded my 09 F250 with 5.4L, 20" Wheels, and plow package and FX4, for a 2011 F350 with the 6.7L diesel, 20's, and plow package and FX4. I notice right away that the front is at least an inch maybe two lower to the ground than my 09 F250 was. I don't really care for that. It's not that the rear is higher, that's okay - but the front is definitely lower to the ground, with less room in the wheel opening. Appears I have the 6000LB stock front coil springs.
After researching some options, I'm left with confusion...track bars, camber, stiffness, shims, blah blah.
I don't mind the rear a bit higher - but I want the front higher for sure. My F250 was nice and level. Again, doesn't NEED to be level, but I want a mild front lift. I don't plan installing bigger tires, etc.
I am wondering if I might get some opinions regarding the options I am trying to decide upon.
1. Leave it alone.
2. Replace stock coil springs with the 7000LB AAB springs and get an alignment. Stiff ride, 3/4 lift, stock track bar and shocks.
3. Add a ReadyLift 1.5" spacer (marketed for the F250 but confirmed will work with F350 as well). Get an alignment, stock track bar and shocks.
4. Both 2 and 3 but add adjustable track bar and longer shocks (might be more than need).
I'm also considering the Bilstien 5100 as an upgrade to the ranchos I have - not sure if that's a waste of cash with only 700 miles on the ranchos.
Any help or suggestions would be appreciated.
Thanks,
Jeff
Old Sep 26, 2011 | 02:44 PM
Dr. T's Avatar
Dr. T
Jeff,
No matter what you choose for a lift or not you should replace the stock Rancho shocks. I pulled mine off at 5000miles and they seemed completely worn out. I fully compressed one of the fronts and it just sat there......never extended at all. The Rancho RS9000XLs I put on have made a great difference. I kept mine at stock height.
Old Sep 26, 2011 | 02:47 PM
aquasport17
Originally Posted by Dr. T
Jeff,
Seems like solid advice from what I have been reading. I'll factor in an upgrade on the shocks as part of the deal. You'd think Ford would use a better shock at least when you pay for the FX4 off-road package. 62K sticker price and I am already changing stuff!
Thanks for the reply.
Jeff
Old Sep 26, 2011 | 03:02 PM
aquasport17
What made you pick the Rancho over the Bilstein?
Old Sep 26, 2011 | 03:08 PM
Dr. T's Avatar
Dr. T
I wanted to give the Rancho "MyRide" system a try. Now I just have to find a good place to mount the compressor and controller.........there is NO room in the engine compartment!
Old Sep 26, 2011 | 07:43 PM
DrewF's Avatar
DrewF
This is interesting. My 2011 F250 CC, SB with the snow plow prep, the front is HIGHER than the back unloaded.
I have no plans to put a plow on it either.
slapshot12
Mar 2, 2019 12:28 PM
rally68
Mar 26, 2016 12:35 AM
mdr617
Nov 15, 2010 01:16 AM
Flux
Jan 26, 2007 04:04 PM
StanleyZ
Oct 31, 2004 01:35 PM
