460 questions
the truck is really gutless because it should be able to at least make the tires spin when you take off hard with the truck empty, not even a squeak out of the tires. pulling a 16 foot flat bed tandom axle goose neck trailer empty you really have to mash the throttle down to go up a slight incline going down the freeway. I read in one of the responses about the cat. being plugged?? how can I check this? cut it off and use a "test pipe" The truck had a new trans put in it several years ago but only about 20,000 mi ago. to me it shifts too fast into OD and takes alot of throttle to shift down. Is a normal of this trans? What are some mods I can do to this truck bring up the power without a huge bundle of cash.
I made a swap like this although not on that new of a truck. I had a 429 CJ and a super sharp 79 f100 explorer. Truck was an original 302 a-t with air. To make the swap go easy I bought an 78 lincoln with a 460 for $200 bucks. I used all the engine accessorie brackets from the lincoln to make the ac,ps and all work on the 429. Used the tranny out of the lincoln and shortened the lincoln driveshaft and used it in the truck. Only thing we did to the tranny was add a shift kit. What a sweet ride. I think if I was you I would do about the same and use the tranny out of the lincoln to get away from the electronics and you would have a fun ride then.
(pickups didn't get Lima engines until after 429 production ceased for passenger cars)
Now, there are plenty of long snout 429's (both gas and propane) in larger trucks like F700's.
But then you have to turn the crank and mess with a whole bunch of stuff to make them work.
X2 on Reincarnation High Performance.
The Man knows his stuff!
Headers and a single 3" exhaust would help.
4X4 and a side tank make true duals pointless.
MAF trucks were '96-7 Cali only.
Conversions are expensive.
I have a gearbox, but Baumann makes an OptiShift controller+ harness
And Transgo has 1/2" valve bodies, these are not as expensive.
Beyond that I don't know much about E4OD's
I searched up this thread... https://www.ford-trucks.com/forums/7...ft-module.html
I agree with Nevada Al, if your that close to Scotty J he is your answer. That dude can help you out. If your serious about making it run do what he tells you. I told him I wanted mine to pull like a freight train, did what he said and it pulls like a freight train. It even got an average of 1.3mpg improvement while doing this.
monstertrucker
17
03-15-2018 05:38 AM
Jaredpizzino
01-06-2016 07:20 PM
piratebronco
07-25-2011 12:38 PM
jwmustangman
01-31-2006 08:42 PM
