Ranger Life Span
Old Sep 4, 2003 | 08:58 PM
gband's Avatar
gband
Ranger Life Span
I have a '94 STX supcab with 165K miles on it. I bought it new in 94. The only thing I have had to fix (other than standard maintenance) were the rear brake calipers. I'm shooting to get 250K miles before I give it up. Its a great truck
Old Sep 4, 2003 | 10:40 PM
jt-stl's Avatar
jt-stl
Ranger Life Span
My 94 had 172K on it when someone decided it was still in good enough shape to steal it. My brother just picked up a 94 and his has 148K on it, it runs and feels better than my 98.
Old Sep 4, 2003 | 11:35 PM
Peter94's Avatar
Peter94
Ranger Life Span
My 94 4.0l 4x4 had 98k on it when i bought it and now it has around 106k. had to replace starter, some belt pully, battery, front brake calipers. still has *****, hoping to have it a very long time. No body rust at all. looks brand new
Old Sep 6, 2003 | 05:17 AM
kmans777's Avatar
kmans777
Ranger Life Span
88 Ranger 4x4, 2.9L, 5spd. 301200 miles. Going strong. No work done on engine. Just replaced water pump at 298,000. Radiator at 265,000. Slave cylinder at 200,000. Trans at 164,000. Clutch changed same time. Replaced coil a couple of weeks ago. Brakes front and back- on 3rd set now. Heater core twice. No front end parts replaced other than shocks. Tie rod ends getting some play in em now. It's a daily driver. Been taking me back and forth to work since I bought it brand new. Only let me down once and that was when the radiator let go. Been a great truck, Looking for a F-250 power stroke now, then will give truck to my son. These are the best small pickups in the world.
Old Sep 6, 2003 | 10:01 AM
AirborneRanger's Avatar
AirborneRanger
Ranger Life Span
I ordered my '94 XLT Suprcab 4.0 4x4 in late '93 and it's been faithful ever since. 98,000 miles, no rust and electric red paint has held up real well. Ordered with largest tires available/offroad suspension/positraction. Now running 31x10.50 on the stock cast wheels. No major mechanical costs incurred in 10 years. Plan to keep it until it becomes a yard ornament.
Old Sep 17, 2003 | 02:12 PM
Ranger95's Avatar
Ranger95
Ranger Life Span
Just by reading your post gives me hopes on my newly adquired "old" Ranger, is a '95 XLT Supercab V6 5Spd with 134,000 when got it about 2 weeks ago (it have 136K now!) I've noticed that you guys can run this truck into the 200K+ and even more mileage. So I guess that gives me hope on mine. Thank you guys.
Old Sep 17, 2003 | 02:36 PM
DRASH's Avatar
DRASH
Ranger Life Span
I GOT MY 85 RANGER IN 99 WHEN I TURNED 16 IT HAD 130000 MILES ON IT IT TOOK 2000 DOLLERS TO GET IT TO PASS SMOG AND RUN GOOD THE PREVIOUS OWNER DIDENT TREAT IT GOOD AT ALL I NOW HAVE ALMOST 200000 MILES ON IT AND IT RUNS BETTER THAN EVER!
Old Sep 17, 2003 | 03:44 PM
AG4.0's Avatar
AG4.0
Ranger Life Span
I have 110K on my '93, pretty low compared to everyone else here, but I expect it to make it over 200k, I feel that even if the motor goes bad, it'll be worth having it replaced. It showing sighns of need ing u-joint or some sort of driveline work, but until it gets reall bad, I'm not going to worry. Some of the early 4.0's were not that great, the 92 Exploder we had was the worst vehicle I've ever seen, as soon as you'd fix one thing, something else would go bad. It had 90k when we got it and in 20k miles we had to put a new tranny, o2 sensor, hubs twice, the second time we got manuals, intake manifold gasket , front wheel bearings, interior door panels, radio died, not to mention normal maintainance like tires, brakes, plugs and wires. We got a good trade in for it, but the repairs were still more than what we got for it. But 93 models and newer supposedly had most of the problems fixed. Mine has been great.
Old Sep 17, 2003 | 08:23 PM
JOEMAN12's Avatar
JOEMAN12
Ranger Life Span
I inherited a 1991 Ranger about 3 years ago with about 100K on it. To date it has 163K on it and I've only had problems with the RABS. I've replaced brake pads done regular oil changes and had no problems with it. Well I say no problems the other day my speedo quit and about a week prior to that my fuel guage quit so I have a little work to do. Other than that it is still running fine.
Old Mar 22, 2004 | 10:24 PM
adamsck's Avatar
adamsck
1990 Ranger XLT, 137000 Miles, NEVER had ANY problems with it. Just replaced regular items, brakes, light bulbs, clutch, etc.
Old Mar 23, 2004 | 10:45 AM
Izzy's Avatar
Izzy
Cool New 2004
I just bought a new 2004 XLT 4x4. I have had my 95 for 9 years now with 138,000 miles it still runs great. I just have gottent to a point in my life where I can get a new one if I wanted and I did. I still have the 95 not shure if I want to sell it or not. The only problem I have ever had is with the fan and turn signals. Both of these problems turned out to be relays worn out. I have always changed the oils at the recomended intervals. I would get in this 95 and leave from S.C. and go to Calf. in it with out heasitation. I Love Rangers best truck I have ever had.
Old Mar 23, 2004 | 11:10 AM
99 ranger bob's Avatar
99 ranger bob
my 99 has 85 K on it and she runs like a champ only thing it goes through is tires but i tow all kinds of things and dont expect to get rid of it for at least a few more yearsi fully expect 250K out of it
Old Mar 23, 2004 | 02:45 PM
  #28
dcale101's Avatar
dcale101
I have a 2000 Supercab 4X4 with the 3.0 and 4 speed automatic transmission. Does anyone have experience with the longevity of this particular engine and transmission? I have 48k on it now and it runs like a champ.
Old Mar 24, 2004 | 09:11 PM
  #29
SUPJDO's Avatar
SUPJDO
88 2wd 2.0 bought in 92? $75 85k now it has 200k (changed motor-2.3 @ 159k)still runs recently bought a 97 4x4 4.0 xlt xcab with 165k on her. not dissappointed ( so far) keep your ranger stock and keep your mait. up should have no problems. good luck!
Old May 28, 2017 | 12:57 AM
  #30
Stephan reynolds's Avatar
Stephan reynolds
My 97 XLT 2 WD 5 speed 2.3l has been in the family for over 13 yrs. It's been well maintained but not driven gently, I abuse it daily on my long commute to work and with over 400k miles on it all original engine/ transmission running gear... I wonder whether to rebuild the engine and transmission or drive it until the wheels fall off. the clutch was replaced about 5 yrs ago and feels strong to this day, The entire truck just feels strong and sound.
