Drivers front clunk
Old Sep 24, 2011 | 07:22 PM
tfs2403's Avatar
tfs2403
Drivers front clunk
Hi all,
I have a 01 ex with the 5.4 (works for me) - 118,000 miles
I have a clunk I hear only on the drivers side only when I hit bumps. Going down the road you do not hear it, but hit a bump and pothole I ll hear the clunk. I dont really feel it in the steering, feel it more through the floor board.
I bought the truck about a year or so ago so I do not know what past maintenance has been done to it.
I started grabbing and pulling on things underneith and everything seems tight.
Any ideas? Ball joints, hub, shock? front end ?
I did not jack the truck up and check things that is my next step.
ANy other ideas?
THanks for any help.
Robb
Old Sep 24, 2011 | 07:59 PM
gr8scott72's Avatar
gr8scott72
Originally Posted by tfs2403
Hi all,
ANy other ideas?
Robb
Probably the front sway bar end links.
Old Sep 25, 2011 | 06:24 AM
bigwhitetruck01's Avatar
bigwhitetruck01
Check the sway bar mounts and sway bar end links. Sometimes the bolts back out a bit and cause a loose connection to the frame.
Old Sep 25, 2011 | 06:44 AM
golfmedik's Avatar
golfmedik
I've had the same problem with my X as well. New sway bar mounts and end links didn't stop it. Next, going to replace body bushing under driver's feet. Having a hard time finding one though. Might even try re-torquing the bolt that goes through the body bushing. Somewhere around 90 ft lbs I believe.
Old Sep 25, 2011 | 06:53 AM
hhcobra's Avatar
hhcobra
When you say you feel it in the floor board it makes me think it is the body mounts. There are six holding the body on and the one that seems to get loose first is the one under the drivers floor board. It is located under the sloped area under the brake pedal. Pull the carpet back and remove the rubber plug and you can see the nut. I think they make a shim that can tighten things up. Do a search for body mounts. HTH!!!
378wby
Dec 7, 2013 02:30 PM
mrbingsx
May 9, 2012 04:55 PM
Diesel32773
Apr 25, 2011 06:58 PM
Haveyoudrivn1lately?
Mar 27, 2009 09:49 PM
