Coil spring spacer?
Old Sep 23, 2011 | 10:01 PM
Prof2113's Avatar
Prof2113
Coil spring spacer?
I was chasing a noise under the truck tonight (was a lower shock bolt, I recently replaced coils and shocks), and I noticed that the cast steel spacer/seat under the driver's side coil is about 1/2 inch shorter than the passenger side.
I had noticed since putting on the new coils last week, that the driver's side set a bit lower, but attributed it to fuel, my butt in the seat, etc. I am wondering if this is common, or has someone replaced the piece somewhere along the line and got the wrong one.
Thanks for your input as always.
Old Sep 23, 2011 | 10:42 PM
Edgethis's Avatar
Edgethis
There are shims that are sometimes put on from the factory as different trucks sometimes lean more one way of the other. Also a previous owner may have put some on.
Coil Spring Spacers, Pair
Old Sep 24, 2011 | 09:44 AM
Prof2113's Avatar
Prof2113
So I could search out a taller one for the driver's side to get it back level, right?
Old Sep 24, 2011 | 10:24 AM
Edgethis's Avatar
Edgethis
Well they are stack-able up to an inch.
Old Sep 24, 2011 | 11:13 PM
Prof2113's Avatar
Prof2113
Well, the passenger side spacer is about 1 1/4 inches tall and is a solid cast piece. The driver's is about 3/4" to 7/8' tall and is also solid. I am thinking about either buying some 1 1/2" tall aluminum spacers, or making my own out of steel to level it out.
Old Sep 25, 2011 | 05:16 AM
TexasGuy001's Avatar
TexasGuy001
I'll look at mine and post back.
Towman4u
18
Aug 29, 2015 03:58 PM
fordka
WTB - Parts & other
Apr 11, 2013 09:08 PM
Dustin_86
Oct 12, 2004 09:26 AM
