Sponsored by: Real Truck
Overload Spring Bump Stop Issue
Old Sep 24, 2011 | 08:52 AM
samsdad02's Avatar
samsdad02
looks like you have worn away a lot of the leading edge of the rubber. try flipping the trailing end for the leading end.
Old Sep 24, 2011 | 03:15 PM
buck_'s Avatar
buck_
Originally Posted by patrhynes
Here is a picture - the spring rubs on the back edge of the bracket. It also did this with a heavier camper.
Something about this does not look right, to me. This setup looks exactly like my 89 F-350. Same bracket shape, same push in rubber bumper pad, and the bracket is even with the top of the chassis.
My 06 F-350 cab & chassis truck looks nothing like this. As others have stated, that bracket on my 89, 06, and Dad's 03 are all riveted, not bolted.
I understand the OP has a F-450, but me thinks this bracket is not correct.
Buck
Old Sep 24, 2011 | 03:19 PM
user 690824245's Avatar
user 690824245
Banned
I bought this truck from my brother-in-law who ordered it from the factory. There has been absolutely no work done on the suspension (other than shocks) since it was received from the factory. In checking the back of the bracket, the holes are not oval and there are no other holes. I think this was a design issue and was probably fixed in later builds. I will try to swap the rubber stops around to see if that makes a difference.
Old Sep 24, 2011 | 04:37 PM
bucci's Avatar
bucci
Originally Posted by scraprat
Look how clean that is. Is it spray with under coat or painted? I'm starting to think I need to stop driving some and do a little detail.
Thank you for the compliment. The frame from the rear of the cab back is painted with Eastwood rust encapsulator and top coated with Eastwood satin chassis black. The sub frame of the dump body that sits on the chassis is undercoated and some of the under coating is oversprayed on to the chassis.
From under the cab to the front, the frame is painted with rust encapsulator and topcoated with extreme chassis black. I think the extreme chassis black is alot better and more durable than the regular chassis black.
Old Sep 24, 2011 | 04:47 PM
hotroddsl's Avatar
hotroddsl
The rear bracket should extend above the frame by 7/8" and becanted slightly tword the front, that is a front bracket! Has a hitch been installed or anything, as some hitch plates do not fit properly on the 450 and 550 so instead of correcting the hitch plate substructure they swap out the rear bumpstops for fronts as they do not interfere that way!
Old Sep 24, 2011 | 10:46 PM
Kenworth's Avatar
Kenworth
That is definatly not factory my F-450 cab and chassis isn't like that I don't get any squeeks from the overload springs all beit it does take about 2 tons before the overloads touch. The overloads touch when I have 11,000lbs on the deck of the truck
Old Sep 25, 2011 | 05:36 AM
scraprat's Avatar
scraprat
Top Answer: 5
Looked at my F350(sig) last night and that's identical looking setup, including the bolts and not riveted.
Old Sep 25, 2011 | 07:09 AM
bucci's Avatar
bucci
1) Does he have a chassis cab or pickup?
2) Is the chassis cab setup different than the pickup?
Old Sep 25, 2011 | 07:24 AM
spinella's Avatar
spinella
[quote=patrhynes;10843055]I have a 2008 F450 that when I put my camper on, I have a major squeak in the rear suspension.quote]
i'm going to assume its a pick up, because he's putting a camper on.
Old Sep 25, 2011 | 09:38 AM
bucci's Avatar
bucci
[quote=spinella;10848768]
That's what I thought too, but there were comparisons made to chassis cabs and if a hitch plate was put on. Hitch plates are like what I have and usually installed on chassis cabs. I just thought maybe I assumed wrong.
Old Sep 25, 2011 | 09:56 AM
spinella's Avatar
spinella
the OP has'nt offered up any other info. i checked his gallery...no pics. its tuff to come up with answers when you only have limited info. it definitly does'nt look right. the angle is way off. i can only think that a hitch was installed and the installer moved the the brackets down like that. maybe he'll post back with more info.
Old Sep 25, 2011 | 10:56 AM
tgreening's Avatar
tgreening
It's not a cab and chassis, and it most certainly is a factory set up. Sure are a bunch of guys making definitive staements about gear they don't own.
On the OPs model year the front hangers are riveted and the rears are bolted, in the exact configuration shown in his picture, and those are factory brackets with factory snubbers. Othe rmodel years may vary.
I'm guessing his issue arrises from the fact that It takes a fair amount of weight to put the 450 completely on its overloads, and keep it there.
Point being to the OP, it's normal, there is nothing wrong with your factory brackets or rubber, and not much to done about it unless you add bags and remove the overloads.
Old Sep 25, 2011 | 11:41 AM
  #28
spinella's Avatar
spinella
i just shot up to my local ford dealer. first pic is a 2008 f350 srw.
second pic is a 2011 f350 srw
tgreening is right. the front mounts are rivited and the rears are bolted. anyone know if the OP's pic is loaded? or unloaded? both pics are of the rear mount.
Old Sep 25, 2011 | 12:48 PM
  #29
spinella's Avatar
spinella
maybe these would help?
Torklift Stable Load Contact Overload Spring Pad Bump Stops
Old Sep 25, 2011 | 01:40 PM
  #30
northwindone's Avatar
northwindone
To second what Tgreening said, I was looking at my truck out of curiosity after reading this thread and even though I have a '99, mine looks exactly the same. Riveted front and bolted in back with the spring making contact in the same place as the OP's. In fact, I can see the rubber is more worn in the front edge than the back. In addition, it looks like the overload hits the rear stop a lot more then the front judging by the wear patterns on the spring and pads. My truck has not been loaded down since I bought it and the PO didn't load it much either, so it's probably from off-roading and first owner(s).
